8.1l Won't Start, No Power
Hulk1999
Truckers,
I need help bad! This morning i went to start the truck. I opened the door, all my cabs lights came on. Went to turn the key to start and there was a click and then everything went black. I was thinking a fuse had blown or something. I looked at the ignition fuses they seem fine. I couldn't tell if the "big" sqaure fuse/relays were good but i'm assuming they are. I tapped the starter to see if it was stuck. Nothing happen no power. I disconnected the battery and connected it back and still nothing. The battery is a brand new replacement for a Optima red top that would hold a charge. What could it be? My buddy, who gave me a lift, thinks it might be a starter soleniod in the steering column (he's a ford guy, so i don't know if GM does it that way).
My truck is a 2001 Chevy 2500HD 4x4 LS 8.1L Auto Ext Cab.
HELP Please!!!
Darrel
Ok check this out, my boss left me off early today to go jack with my truck. I try to start it again and nothing, no power at all. We'll i've been reading up on the issue all day today. I looked on three different GM truck forums. I kept seeing things about a neutral start switch. I didn't know where the switch was so i decided to apply the parking brake, shift to neutral and try a crank. BAM! the beast comes alive like it was taking a nap! Does anybody know what happened exactly? I'm gonna figure it out in the mean time. Thanks for all the help guys!
:lol:
Darrel
:lol:
Darrel
did you say everything was dead or just no cranking power
:lol:
Darrel
i asked because i had a similar problem with my old camaro w/ floor shifter all was dead until i pulled it out of park to push it closer to the shop & bam all the power i needed , two days later the car skoked the shifter cable along with my console & part of my carpet , i had a bad ground under the hood & when i pulled the shifter it found ground through it and got hot & well you know..... so by applying your park brake you might have done the same thing check all grounds under your hood carefully you must have a ground wire goingfrom engine to frame & to battery & to body ,,,don't get burned like i did!!!!!
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 964 Guests (See full list)
