Heys guys, i have an 06 z71 crewcab and the drivers side door is already sagging. I had the dealer fix it when i bought it and it's already doing it again. It wouldn't bother me so much if not for the wind noise and slight rubbing noises on rough roads. Is there a cheap fix or trick that will fix this because the body shop i spoke with said i was looking at 400 bucks or so for parts and labor. Thanks in advance!!
the pins are not hard to change.........buy some at your local parts store.......hammer out the old ones and hammer in the new ones....chances are the bushings are what are bad not the pins themselves
For an '06 it should be under warranty. Let the dealer fix it.
Make sure you explain you don't want it back till its fixed right.
