Csk Getting Worse
jhm
My '01 4.8 never had any csk or piston slap or any other engine noise. About 3 years ago it would make what sounds like csk only in the cold winter months then go away after about 30 seconds. Since then it has gotten to the point it makes the noise even in warm weather and lasts longer. I am wondering is something wearing out? Could worn lifters be the source? :lol: I have always used 5w30 convetional oil, changed out at 3k.
Are you consuming more oil than normal? Maybe try a can a sea foam to see if it is a carbon buildup. My only other guess is that the tolerances are way out of spec and it may be time for a rebuild.
No, actually I never need to add any oil between changes. I am beginning to agree it could be carbon since so much of my mileage is rural. I do take it out on the highway and run it 70-80 now and then, maybe it is just not enough crappy ethanol in the gas probably dosent help. Other than the start up noise it is a real strong runner.
On those models when u get some milage on them u notice when u use an oil filter without a check valve and notice lifter tap! Usually switching a sythic oil on the older models and using a old oil filter with a check valve usually rids of this noise. Usually the 4.8 devolpes the lifter tap before the 5.3 everytime in milage!
since this noise goes away after 30-40 seconds, do you think it is lifter tap? How do I find oil filters with check valves?
Its lifter tap if it goes away most of the time. Yea the k&n have the valves most of the ac delco do and some of the frams do also just have to check on the frams alot for the chevys say they do but they really dont on the frams.
I been using Carquest, not sure about the anti drain back valve on them. I will check. Thanks for the help.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
