What Is This Extra Wire On The 7-way Harness?
I was looking at my 7-wire trailer harness and found an extra wire capped off really nice. This is all stock stuff on an '05 Sierra, w/ tow package. What is this extra light blue wire for?
I will attempt to post pics below:
With cap on:
With cap off:
Its for a third brake light.
So if I wanted to get one of those nifty receiver hitch - light up brake lights, I would hook it up to this? Just the one wire?
Yup. Grounds through the receiver to the frame.
Bish....Where the heck ya' been man? Haven't seen you on here lately!!
Hey thanks for noticing :D
Not here much unfortunately. Lets see where shall I start, my business that employees 18 people is struggling with the economy, my government is making every wrong decision on almost every issue IMO, my wife shattered her ankle (right) 5 weeks ago today and has 7 pins and a plate, I have had to try and run my struggling business while shuffling my 12 and 13 year old daughters to every god damn thing you can imagine, while I cook and clean............well, I got to calm down :thumbs:
Bottom line, it sucks to be me right now :cheers: I have NEVER appreciated my wife of 17 years more than in the past 5 weeks.
Good news, she can walk across the room without the boot and I'm hoping she is able to drive herself to work in about a week. Taking the family to Florida last week in March so we can all decompress a little. Hope to be back on the board more in a month or so when my life gets back to normal.
Thanks for asking and thanks for letting me vent. Sorry for going off tpoic but you asked :flag:
Hey thanks for noticing :flag:
Not here much unfortunately. Lets see where shall I start, my business that employees 18 people is struggling with the economy, my government is making every wrong decision on almost every issue IMO, my wife shattered her ankle (right) 5 weeks ago today and has 7 pins in a plate, I have had to try and run my struggling business while shuffling my 12 and 13 year old daughters to every god damn thing you can imagine, while I cook and clean............well, I got to calm down :thumbs:
Bottom line, it sucks to be me right now :D I have NEVER appreciated my wife of 17 years more than in the past 5 weeks.
Hey,No prob'....I "did" ask :flag:
Hope your wife gets better soon :cheers:
Thanks for asking and thanks for letting me vent. Sorry for going off tpoic but you asked :lol:
Ouch, sorry to hear about all that...Maybe a little trip to "sunny" Florida will help a little bit, just don't expect to get anywhere fast here. Between construction and congestion all the main highways are pretty busy at peak hours...
If you do drive down, give me a holler if you're gonna be in the Orlando area.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
