Rear Axle Seal
Hello all,
I'm new here and trying to help out a friend. He has a 1999 sierra 2500 6.0 4X4 late year. Trying to figure out how if this is a floating axle and how to pull the rear axle seal off. Is the seal at the differential or at the hub? Are there any special tools need to replace, like a seating tool?
Thanks for any replies.
Lou
A non full floating will not have that big intrusion in the center. I believe the 2500 does have full floating though. Check it out to make sure.
Pretty sure the seal is at axle tube end (wheel side). Someone else should chime in to tell me if I'm wrong.
EDIT: Someone else should chime in with what tools are needed, I've never pulled the axles out of a full floating axle.
My 2000, 2500 with 8600gvw has a semi -floatng axle. I didn't think they went back to full-floaters untill the HD's.
Mark
From what my friend is telling me there were 2 different 2500 models in 1999. one with semi & the other with full floating.
I got this off of rockauto and they list two (besides the length)
1999 GMC SIERRA 2500 6.0L 364cid V8 FI (U) : Drivetrain : Axle Shaft Price Core Total
AUTO UNLIMITED Part # 2284 {8 lugs; 30 spline; 14 cover bolts; 10.5 ring gear; 33-3/8" length}
SIERRA REAR LEFT; SRW FULL-FLOAT
$123.79 $0.00 $123.79
AUTO UNLIMITED Part # 2594 {8 lugs; 30 spline; 14 cover bolts; 10.5 ring gear; 39" length}
SIERRA REAR RIGHT; SRW FULL-FLOAT
$154.79 $0.00 $154.79
AUTO UNLIMITED Part # 2458 {8 lugs; 33 spline; 14 cover bolts; 9.5 ring gear; 33-1/2" length}
SIERRA REAR; LEFT OR RIGHT; SEMI-FLOAT EXC HEAVY DUTY
Can anyone confirm that the full float axle has a seal on the backside of the hub? It looks fairly easy to replace, but is there a hub lock/special tool?
Thanks for any help,
Lou
Is it heavy duty? I would think that would clear it right up.
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 0 Anonymous, 840 Guests (See full list)
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
