College Basketball
pennzoil29
It look's like UCONN and Villanova are going to be it. Some wild upset's took place over the weekend. I had originally picked Memphis, but Mizzou put an end to them.
No way UNC will win it all.
There have been some great games so far and I expect a couple more good ones.
I been only watching the MU tigers play. I am surprised they did that well in the tournament. Can't wait until next year. Now I have baseball.
Watch out for SPARTY!!!
No one thought they were even going to keep a respectable score against Louisville, then they completely shut down the overall number 1 seed in the tournament, nearly held them to under 50 points. still nobody on ESPN is talking about IZZO and Michigan state. playing only an hour away from their home campus, Ford Field is going to be electric on Saturday!
How fitting would it be that Michigan State and UNC played each other earlier this year at Ford Field and they could meet again at the exact same venue to decide a national champion!?!?!
I'll be cheering on my Spartans!
Being an Ohio State fan, I'm not to fond of any Michigan teams, But I'm going to have to pull for Michigan State, just because they're in the Big 10.
Big 10 = overrated
UNC owned the not so mighty Spartans.
Big 10 = overrated
I guess the same could probably be said for the Big East, given that they couldn't get a team into the finals. :cool:
UNC punched MSU in the mouth right at the beginning of the game and State could never recover. Was sort of a disappointing game, I would have rather it be a closer one so that it was more entertaining to watch. I think I stopped watching the game intensely half way though the first half to go poke around in the garage.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
