Ecm Leveling Kit
EDIT: good point on the posts below. Just crank the torsion bars up, but remember that if you go too far your ride will be harsh.
Thanks for the reply, Is their anything else i need in order to level my front end with the back or just installing the Torsion keys will do the job.
Its actually from CCM. They make leveling kits for just about anything. For your truck it is not needed. You can just crank your t-bars with your stock keys and get the same results. I would do about 1.5 - 2" max.
They do the exact same thing. With torsion keys, all it does is allow you to crank the front end way to high to the point where you have extreme premature wear/failure of front end components.
To be safe, just crank the stock keys about 1.5".
Exactly!
No problem. If you are not familiar with how to adjust your t-bars, search around. There is TONS of info about this very subject.
I am also going to be getting new tires soon, i currently run 265/70 17's
i have been looking at the toyo open country A/T will i be able to put 33 inch tires after i raise the front end up 2 inches
every place i have go so far have told me if i go any bigger then 265/70/17 then it will put me over the 3% limit(whatever that means) anyways my other option is 285/75/17s which will make it 32.9 inches, do you think that will work after i raise the front end.
    C. Hart
    C. Hart
  • Who's Online   2 Members, 0 Anonymous, 556 Guests (See full list)
