Need Help....speaker Is Staying On
firehawk001
i have a 2007 extended cab z71 silverado. the back left speaker is staying on. all that is coming through it is distorsion. what do i do? it is staying on without the keys in it and when i hit it it will go off for a few seconds then turn back on. need help please!!!!!
I'd chek the speaker connection at the speaker and headunit. Might also pop up the door sills and have a look see for pinched wires.
More details may help too, GMT-900 or 800 (GMT-900=Current Body Style), radio type, bose or no bose, any aftermarket items...
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 509 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
