Truck pulls
RedDog
Tonight I went to our fairs tractor pull, where they finished the night out with a street legal 4x4 pickup pull.  I was shocked at the number of brand new trucks entered, Chevy HDs, new Ford Super Dutys, a few new Dodges.  Sure wouldn't see me entering one if I had a brand new thing.
To play with the big boys you had to have a three quarter ton or one ton truck with a big block or diesel.  Those poor fools with the half tons should have stayed home, small block v-8s seemed to run out of power about three quarters the distance the big blocks made it.  One Duramax pulled and he did the best of all the Chevys new or old entered, outdid the Powerstrokes and the lone Cummins entered also.  The newer Fords didn't do so hot, but the older ones were OK.  Not many Dodges were in it, but they were all 1500s, so they didn't have a chance, one Cummins was in it and had a respectable finish.  What none of them came close to touching were the two old IH trucks.  They just kept going and going.  The one that won it snapped a U joint while he still had a few feet left in him, yet won by about 10-15 feet.  Goes to show you that they just don't build trucks like they used to.
I really don't know much about truck pulls, but when these guys start getting serious, the Dodge/Cummins combo is basically unbeatable.  I need to get RedDog to post about this, because he knows alot more about truck pulls then me.....
AMEN, brother!!
  At local county fairs you will see a lot of the locals that think they have a "bad truck" enter.  Depending on the weight class,, 1/2 tons can pull just fine.
   If I had a new truck, I would pull it.  It is under warranty should something go wrong, but I doubt it..  Todays trucks have factory built in rev limiters,, you ain't going to hurt the motor,, if you do, it wasn't build right to begin with..
     I am diehard GM,, but for diesels right now,,, Dodge Cummins is virtually the best combination out there for pullin,, with the standard tranny.
   RedDog
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
