Price For Djm 4/6 Drop
I called a local lift / lowering shop and asked for a quote on a 4 inch front / 6 inch rear lowering kit for my 1995 C1500.
The guy called me and told me they'll do the installation for the DJM 4/6 lowering, new suspension (didn't find out what brand) and align everything afterwards for $1200. Is that a good deal? :D
EDIT: I know the DJM 4/6 kit is 600.
I know when I called about lifting my truck the labor was about 800 so I would assume it would be about the same to lower. I would say its not a bad deal.
