Benelli Super Nova 12 Ga
bigBP
Think I'm gonna be looking at picking up a new turkey gun this weekend, been looking at the Benelli Super Nova with a Steady Grip. 12 ga, 3 1/2" chamber, 24" barrel. Anyone had any field experience with this one, has it treated you well?
The past couple of years I've been using 2 3/4" turkey mag rounds. I've shot a 3 1/2" before, about tore my arm off, but I like the extra reach it's got. Plus you should only be shooting once right. :D
Thanks
I've got a regular Nova. I really like the gun. The only difference between our guns is the recoil system. I haven't fired any 3 1/2's yet, but 3's have been no problem. With the recoil system that the super nova has plus the fact that you will only have to shoot once I wouldn't worry about it too much. It's a nice gun. Enjoy!
speaking of turkey guns.. haha
i've just got a Remington 20 ga. 870 express magnum.. its shoots a 3" shell so thats what im gunna be using on my first turkey hunt coming up on April 19!
im so excited :thumbs: ive done some hunting big game elk, deer, javelina, and small game dove, squirrel, quail, etc but i have yet to go turkey.
Its a wondefull gun. Minimal kick, triggers right, smooth operation. I recommend it to any one. Gander Mountain usually has good deals on the Super Nova 3-4 times a year.
Whelp, went down to look at a Super Nova and wouldn't you know it, they had already sold the couple they had in stock. I was sorta bummed out, and proceeded to just browse around. I happened apon a Mossberg, picked it up, and as I had it to my sholder thought to myself, hmm, I like the feel of this. To make a long story short, I'm now the owner of a Mossberg 535 ATS Tactical Turkey Series 12 ga w/ 20" barrel. Shot is a couple times this afternoon and you can definitely feel the 3 1/2" mags, but this thing should be a turkey killing beast. Nice tight balanced pattern at 35 yards. So, now I just gotta go out and call a big one into range! :crackup:
im so excited :crackup: ive done some hunting big game elk, deer, javelina, and small game dove, squirrel, quail, etc but i have yet to go turkey.
Trust me, once you call a turkey in for the first time you'll be hooked for life. For me turkey hunting is right up there with bow hunting for deer. I used a 20 ga back several years ago for my first couple of turkeys, just make sure you know the shot pattern of the gun and remember your range isn't that of a 12 ga. I don't know how the Rio Grande turkey is to hunt down by you. The Easterns here in Michigan can make for a challenging hunt (I've heard they are the most challenging of the species to hunt, not sure if there's any stock in that or not?)
I have the super nova and love it!! The tactical mossberg is nice as well. The only thing I didn't like about the mossberg was the forend grip was a bit to flimsy for me. Although the one I held was used. I have a mossberg 500 "Just in case" and that is a baaaad mother ****er with 3" nitro mags
I bought my Benelli Super Nova this past November and I have no complaints at all. I have yet to fire a 3 1/2" shell yet, but its still a great gun with minimal recoil. IMO its much better qaulity than the mossberg, but in the end they both will acomplish the same thing.
Just sold one 3 weeks ago for $250, had maybe 10 shells shot though it, not a turkey one. I bought it a few years back to shoot geese with the 3 1/2, very nice gun for the money, thought it was at tad heavy compared to my others. I kept a 3" Charles Daily over the Nova and 870 Rem, not that the Charles is a better or worse gun, I liked the light weight, the feel, and it just fit right for the limited shotgun hunting I do. Now that I think of it, Minnesota has a early Turkey hunt, Thanks for the post.
im so excited :lol: ive done some hunting big game elk, deer, javelina, and small game dove, squirrel, quail, etc but i have yet to go turkey.
yeah im really excited, ill post pics and a story probably at the end of the hunt :D
k sorry. end hi-jack :D
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 396 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
