Code P1416
od3368
I have a 99 Yukon Denali and it recently had an engine code pop up. A local oil change place was able to get a code of P1416 on their scanner, but did not have the book to decode it. The next day, the light went off, but today the car won't start (it just clicks). After seeing the advice about the emissions check valve, can anyone say if "not starting" is a possible result of that issue, or should the car have just gone to limp mode? Thanks for any help.....Dan
Hey Dan...check this out and see if it helps....
gm-trucks.com topic 60038
If this isn't any help, try the search function. I am sure you'll find plenty on this subject. Good Luck
    liddlera
    liddlera
  • Who's Online   1 Member, 0 Anonymous, 352 Guests (See full list)
