Talledega
Bill89
Stacy Compton has the pole for Sunday. The Dodge boys have been complaining about there roof ridge, but they kicked ass today.
What's up with 24's new paint?
Yeah, that's why (IMO) NASCAR put more ridge on their roof.
The Dodge teams are doing something that no other team(s) are doing. Any info that one Dodge team comes across, is supposedly available to all Dodge teams. It kinda makes all Dodge cars one "team". I guess that's why Stacy Compton is on the pole and Kyle Petty went home. But you do have to admit, the Dodge boys seem to be working harder than others.
The Pontiacs and Chevys have been okay, Ford screamed and got their spoiler lowered, Dodge got their roof ridge extended and kicked ass in qualifying today.
I think that there is a lot more information exchange in the Dodge camp than anywhere else, but they ain't tellin' everything.
Gordon's paint was a race thing. If I remember corectly he will run the Pepsi car at two races this year.  Yesterday and the Daytona 400 night race.  I think that is it.  I also heard that he won't be changing his paint scheme for the 600 this year.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
