Any Issues With K&n Oil Filters
I run full Synthetic oil and K&N Oil filters, has anyone had any issues with the K&N Oil Filters?
By the way I have been using the Castrol Edge Full Synthetic, any thoughts on this as well?
I like to stick with Mobil1, K&N, or Amsoil filters. I run synthetic Amsoil oil but have also used Mobil1 for years both with good success. I tend to keep my vehicles to around 200K and they seem to hold up well with this combo.
I run royal purple and a K & N oil filter... Have been for last 3-4 oil changes and have no problem at all!
The way i think of it is why put quality oil in and then use a cheap filter! It just dosent make sense!
I've been using Mobil 1 with K&N oil filters in many different vehicles for years now. I've never had a problem with either the oil or the filter.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
