Cold Start Project
well,I am thinking about running my truck on 100% ethanol .
I know that I can install a gasoline resorvoir , a fuel pump ,a switch , and i need to know where is the best spot to install the injector that will send gasoline inside the air induction system (after air filter).
anybody can help me?
After the air filter will probably give the engine more responsive zip, since there will be less dilution before the intake manifold.
Those adding hydrogen electrolysers typically tap in just before the intake butter-fly for acceleration purposes, and after the butter-fly for idling purposes.
You most likely will need to mod the timing, how do you plan to do that? What type of bazoo you customizing?
