89 Chevy Suburban 2500 (pics Included)
Hello I’m selling another vehicle for one of my friends. It’s an 89 Suburban 2500 with a 454 and a turbo 400 Trans. It has a class 5 hitch and runs good. The breaks are a little grabby but that prob. form sitting for a while. The truck is originally from Georgia but has some bubbling paint and the door panels have some crazy carpeting material on them. But other than that the truck seems sold to me. He told me he wants to sell it for $2000 but I encouraged him to give it some wiggle room so please offer and ill see what he says. My name is Michael and I’ll gladly help you with anything you need. The truck is located in Nothern Virginia.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
