Nav Makes Noises - No Keys In
When I open my door I hear like a disc winding up. I don't have a CD in the CD player but the nav has the DVD in it. Is that it making the noises and how and why is it if so. If not any ideas? Thanks!
It's normal. The system is booting up, so you're not staring at a blank screen as long, when you hit the key to start the truck.
It was bothering me because last night when I was taking my door apart because of the broken door handle. I had to poxy the piece that broke until my replacement comes in and let it sit overnight the battery was dead in the morning.
Also I have a space under the hood and looks like it's for a second battery. Is that something I should invest in and would the alternator be able to handle both?
IIRC, the stock alt is only rated for 145-160 amps. There are a few places online that you can get a higher amperage alt to handle a second battery. Also, its just just throwing another battery in and running a wire from the alt to the second battery. I do believe that spot is for the diesel's second battery to get higher cranking amps. I think I remember seeing posts on here about adding it.
No, you shouldn't have to get a second battery to handle the stock nav unit. Did your door not close all the way? I don't have the nav so I don't kno if the deck was on all nite cause of something done to the door.
Has it done this before or was this a first?
I just bought the vehicle so this is the first time it happened to me. But the door was not closed all the way but after 15 minutes the lights cut out. I thought thats why the lights cut out to not use the battery?
Yup, that's what happens but if the nav starts up before you jump in maybe it doesn't shut off like the lights do. Has it happened since?
Oh, and the diesels have two 100 amp alternators from what I have read.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
