Update to rule changes.
Elwood
NASCAR cuts Ford and Dodge spoilers
By KEITH PARSONS
AP Sports Writer
February 15, 2002
DAYTONA BEACH, Fla. (AP) -- Ford and Dodge cars were given a boost just two days before the Daytona 500, with NASCAR making a rules change that trims a quarter-inch off their rear spoilers.
Teams were told of the change, the third since January and the second in five days, late Thursday. Ford now has a rear spoiler of 5 3/4 inches, Dodge and Chevrolet 6 1/4 inches, and Pontiac 6 1/2 inches.
Cutting the height of the spoiler, which sits atop the rear deck of the car, allows cars to go through the air with less drag, thereby increasing speed.
``It's going to take them two weeks to get it done, but they're going to make sure a General Motors car doesn't win this race,'' complained Chevrolet owner Andy Petree, who has drivers Bobby Hamilton and Mike Wallace in the field.
The move came after Jeff Gordon and Michael Waltrip each won a 125-mile qualifying race Thursday in a Chevrolet. No Ford or Dodge led during any lap of the twin races.
Ricky Rudd, fourth in the opener, was the Ford with the top finish. Sterling Marlin, who finished sixth, was the top Dodge.
In the second race, John Andretti finished eighth in a Dodge, and Todd Bodine finished 11th in a Ford.
``If you look at both races, there was a lot of moving around and a lot of passing,'' said John Darby, NASCAR's new Winston Cup director. ``But it seemed, pretty predominantly, that all that was happening between the Chevrolet and Pontiac.
``The Fords and Dodges were passing each other, too, except they were way back there in the back.''
The change was in place for an hour practice session Friday, where Kevin Harvick turned the fastest lap in a Chevrolet.
``I couldn't tell any difference in practice,'' said Dodge driver Jeremy Mayfield, 15th in the practice. ``Our car didn't seem any faster. Everybody seems pretty fast right now.''
Dodge team owner Bill Davis, who put driver Ward Burton in the field but had Hut Stricklin fail to qualify, wasn't pleased with the change.
``It's too little, too late,'' Davis said. ``We're still way behind. I'm not making excuses. We didn't bring one car down here fast enough to make the race. Shame on us.
``It just doesn't look like we can do it Sunday. We can't make progress up through the field.''
Bodine was one of five drivers who didn't participate in the practice under the new rules. He said his crew had too much work to do to improve his car.
``Taking away the spoiler has taken away downforce, so the Fords are a lot looser,'' Bodine said. ``It's a handful to drive. What they should have done, instead of cutting the spoilers again, is add something to the Chevrolets and Pontiacs.''
The Dodges of Stricklin, Jimmy Spencer and Buckshot Jones were among 10 cars not making the Daytona 500.
``It came too late for three or four of the Dodges,'' said Tony Glover, team manager for Chip Ganassi Racing, which fielded Spencer's car. ``It didn't seem like the Fords had what they needed. They look like they're a little better than we are right now, but we'll see Sunday for sure.''
In qualifying last weekend, Jimmie Johnson won the pole in a Chevrolet and only two Fords were among the top 20. Burton was fifth-fastest in a Dodge, while Dale Jarrett had the top Ford at 13th.
And that right there is the key to this whole equation.  For all I care right now, they can keep hacking on that rear spoiler for the Ford and Dodge camps.  Because there is no need to worry about all out speeds now, its all about handling.  This is going to come back and bite the Ford teams square in the a$$ when their cars won't handle about 20 laps into a run....
    Zinister101
    Zinister101
  • Who's Online   5 Members, 0 Anonymous, 664 Guests (See full list)
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
