Bullydog Tuner
You'll get more out of a custom tune than you will a handheld. Where you located, there may be a group-tune near you.
I have no clue why that happened.
I was trying to say that I have the buuly dogg gas handheld and nothing but positive to say about it. It really woke the truck up and I like the idea of it working on all 98 and up trucks with just an internet update .The only prob I had is when installing it had to rip the dash apart and unhook the bypass for my comand start so it could access my trucks comp. As far as handhelds go i highly recomend it.
I had the diablo on my 09 and sold it after 2 weeks because it did absolutely nothing. Getting a BB in the mail sometime this week (hopefully!)
Bully Dog sucks. All they do is repackage the stuff from Edge. Go right to the source if you want a hand held. Diablo makes a good product too. The PCM tune is the best but you don't get the code reader.
first of all id like to say if they rebox edge stuff dont edge mount on dash? this dont. i got it set to perform and its makes a big diff in the truck the low end still kinda laggy but it will really open up now and keep pullin!! the shifts are so much better and kinda throw the truck forward iv never had any other tuners i drove a 1st gen tundra before this and could not get one but i think it works great gives u power u can feel and does not feel like its hurting the truck a bit
Edge has more than one product. Their Evolution tuner is a hand-held tuner which is what Bully Dog repackages as their hand-held (the DP tuner maybe?) Edge also makes boxes that go under the hood to give the power gains with a digital readout on a display that can mount on the dash in a pod or in the overhead glove box where the lights are.
Recently Bully Dog has heard the pop and has started to get their own plastic housing for their products so they look different, but a few years ago the only effort they put to disguising their copies was a different sticker on Edge's housings.
I have about as much respect for Bully Dog as I have for Stupidchips SCMT.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
