2006 Sierra 2500hd (ipod/aux Ideas?)
Picked up a 2006 Sierra SLT 2500HD. It has the Bose 6 CD changer stereo. No XM or onstar.
Are there any after market options for this head unit? Would like both Ipod control and AUX if possible.
If you have something, how well does it work?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
