Tuned Pcm Swap?
I just got my new tune in the mail. Now, how do I install it in my 04 5.3? Where is my stock PCM located? Thanks for the help
Under the hood, drivers side. Near the fuse box. You can't miss it
Yeah,It kinda' sits on top of the driver's side frame rail,right beside the radiator.
Thanks for the help
I'll have to get out there and take a look after work in the morning
Very easy swap;
1. pull the negative battery cable.
2. pull off the plastic cover.
3. using a 7mm socket and wrench, back out the two bolts holding the computer cables.
4. unhook the spring clamp on top of the computer and then remove the computer.
Just reverse the above directions to install the new computer.
Note: if the computer gaskets come out with the computer, make sure you place them back into the computer cables before reinstalling your new computer.
Very easy swap;
That's a good point right there. On my 2005 the gaskets stayed stuck to the OEM computer so I had to take them off and place back onto the connectors before plugging them into the tuned computer.
Very easy swap;
Yep. Same thing happened to me. I had to pull them off the old PCM and stick them back in the connectors. Swap was a snap.
Thanks for the help
Thanks for the help
Well....how does it run now?
Do you like it? :thumbs:
Thanks for the help
Haven't put but about 15 miles on it so far, so it's too soon to know. Charlie says I need to put about 100 miles on it before everything steps all the way up like it should. I'm talking to him right now and I think we're going to go with a mid-grade tune to get a little more a$$ out of her. I just got the regular octane tune this time.
I'm sure we'll get it right and Charlie has GREAT customer service!
Volt
We will get it squared away for you buddy
pm'ed you back by the way
Thanks guys
Wheatley
No doubt in my mind that it'll be rompin and stompin by the time we get everything squared away! Part of it is my fault because this is the first time I've ordered a custom tune, and wasn't sure what to expect. It'll be right in the end, i know
Again, I can't say enough about how great the customer service has been. A+ place to do business :thumbs:
Volt
I'd definitely have Charley tune for higher octane. It's a good HP difference between a 92 and an 87.
We're talking about doing the mid-grade tune this time and change a few things around. There has to be some point where fuel cost outweighs hp (I think) :thumbs:
What say the masses? This is a daily driver
I have a mid grade tune, but you will get better gas mileage along with the HP the higher octane you go. Just saying, been there done that.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 307 Guests (See full list)
