Dad Looking For A Truck
HI, guys. Dad's Grand Marquis just died!!
He is looking to trade in and is interested in a truck He loves my Chevy Silverado (2 door, reg cab).
What kind of incentives is GM offering? Any recommendations? He isn't towing and only needs to haul groceries at his age. He is tall and so probably wouldn't be happy in a little truck.
Thanks
Thanks
My father is about 6'3" and drives a 2005 Colorado Reg cab, stick shift. Seat is all the way back, but he is able to drive it just fine. If he truly wants a larger cabin and little more ground clearance, I'd go with a 2wd (if this is in warm weather climates) ext cab. For groceries it is handy to have at least an extended cab, no matter the truck (unless there is a cap/tonneau cover). Not sure about incentives but I believe there are many deals going on right now for 09 trucks. Finding a used truck, like one just out of a lease, is a good way to save some money. I'd start by looking for low(er) mileage used trucks in your area. If nothing is around, look then going new might be the only option left.
A Silverado sounds like too much truck for him. No reason to buy a truck unless you haul/tow/offroad often. Why not a SUV?
It sounds like he doesn't need a truck for any reason. Get him a nice sedan. He could get a Tahoe or Avalanche, but for what? If it is just him, then there is no need. How about a nice Caddy CTS?
My old lady's grandpa has a 2008 Colorado and it works fine for him. But he's maybe 5'6" or 5'7" I am 6'5" and wouldn't be comfortable in it for very long. :rollin:
I like the sound of the V6 truck. My 99 was a Regular Cab, Short box with the 4.3. Unless he's hauling around a bunch of grandkids, that'd be a nice comfortable riding, easy on the gas, and sharp looking vehicle. Plus it seems like the RCSB go over well with the "seasoned citizens" :lol:
I just got a voucher in the mail for $1000 off any gm vehicle excluding the medium duty trucks.... I'm in Canada though, and I don't know if one if being sent to the states too.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
