need center caps
patgizz
need stock 5 lug center caps for my 89 w/ the lugnuts and the the little caps that thread over em to hold them on.  no local yards have them
  • 11 months later...
Got a JC Whitney catalog today.
81ST4198P   $43.99
set of 4
88-93 1/2 ton 2wd
That should be the 5 lug, the picture they refer to is 5 lug.  There is another part number and it specifically says for 6 lug 1/2, 3/4, 1ton
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
