Drag racing parts
RIPMF
For Sale:Tunnel ram intake upper half is sheet metal 85lb per hr sential injectors,90mm accufab,accel DFI controll box,weldon regulator,dist,wiring for newer chevy truck adapter box but can be used in older cars with new harness for your set-up,also Paxton Novi 2000 blower brackets for 96 truck,vortec blow off,k&n air filter,all aluminum tubbing cog belt, 16lb polished pulleys,came off a 400 sbc makin 880 hp at the crank. $5,800.00 obo Also have the bottom end  of this set-up if anyone would like  it 400 bowtie,lunati pro crank,lunati pro mod rod's,JE blower piston's,lunati custom ground soild roller cam,Brodix Weldtech ported heads with Jesel shaft rockers,Speed-Pro file fit gapless rings,H-series bearing's,Jesel two piece timing chain  or gear drive  cover,bottom is studded and  heads are just ARP bolts,custom stefs oil pan$7,000 obo Thank's Henry
    juggernautusa
    juggernautusa
  • Who's Online   3 Members, 0 Anonymous, 1,294 Guests (See full list)
