Looking To Get A Smoker, Whats A Good Brand?
takevin
I sent a picture from my phone to my email so I could post it up here, but it hasn't come through yet. When it does I'll come back and post it.
The brand is Lyfe Tyme. They're made here in TX, and they're solid, 1/4" steel. I love the thing, I just smoked a 20 lb brisket, 2 beercan chickens, and 4 sausage links this past weekend for a bunch of friends. I don't know if they'll have them outside of TX or not. I like a firebox style because it lets you cook a lot of food over the surface, and if I ever wanted to 'grill' I could just dump the coals under the grates.
http://www.lyfetyme.com/ that's their web site. If you click on Our Pits, I got the 20x40 dual lid with firebox. the thing is huge, I absolutely love it.
You can call them and see if they have retail outlets in your area. The one I got weighs 700 lbs so trying to get it in and out of the bed of the truck would have been a pain. So I ended up renting a trailer to cart it home. If I were to weld up my own, it'd be basically the same thing, just maybe mounted to a trailer (the one they have on a trailer is a tad big for where I live right now). This thing definitely passes the 'shake' test and really will last you longer than you'd ever need it to.
I am the Pitt Boss for a competition team in the Kansas City Area, Big Ole' Boys Bar-B-Q and first you really need to set a price range as how much you want to invest in this adventure. Such as myself I just dropped $2000 for a custom smoker but before I had a couple of water vertical smokers and a barrel style with an offset fire box love them all it is just what you plan on doing and how much you wanna spend.
Oklahoma Joe's is a good brand (never personally owned one but people on my team have them) and they can be found around the country. Very durable and will last a life time if properly treated. Propane fired smokers are become more popular so check into them also. If ya have any questions give me a hollar and I will answer them the best I can.
Good Luck
Justin
Cool thanks, i dont need something quite as big lol. Guy at our horse barn offered a free smoker, so im going to check it out tonight. :)
I have one of those $40 electric Brinkman brand units. Works pretty good and ready to go when I need it. Used to have the one with the coals, but that was a pain. If I were to step up anotehr notch, I would look into the propane model. From there, a buddy of mine has one that runs like a pellet stove, only it has teh hardwoods through the hopper. Pretty nice deal there too, but a little too $$$ for me. I had to weigh amount of use/quantity of food/price when I did my deal, but for the $40, I can sell it at a garage sale if I didn't like it.
--Mike
So the one from the guy at the barn will be work enough for me till i get a bigger one down the road. Its a brinkman too, three shelves for it. One of their bigger ones. So any good tips, websites how to smoke meat :) ? Good wood chips to get etc etc? thank you
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
