Rear end banging
Tonight i was at a stop light it was raining so the ground was wet.  I hit the gas (to race another truck) well rear tires spun and the rear end started banging (clattering).  Any ideas on this
Is this normal for the rear locker?  Havent ever had this happen
yea i know that but dang i have never had it sound like my rear end was falling out of my truck.
I lost the little race.  I sat there spinning and he took off
GRRRRR
