2012 1500 Silverado 5.3L Gas Mileage
alstairs
agreed, the remote start will suck a lot of gas without even thinking about it, i only do it on the hottest of hot days for the ac to kick on and the coldest of cold to let the truck engine warm up.
  • Replies 32
So here is an update. I went on a trip (about 173 miles in each direction) and on the way there I got 18.9 MPG with cruise control on, AC set for 73 degrees with an outside temp of 84 and ALL highway. On the way home I let my wife drive and she got between 18 MPG and 18.2 MPG. The way home was 90 highway and 10 city.
If the truck gets better after a couple of miles on it I may be getting 19+ MPG but that means I have to move further away from work to make it good for me.......
I am still going to try a few things to get better mileage around the city because 11.7 MPG around home is still not acceptable.
I find most people all have different ways of figuring mileage .... and you usually will come up with different answers. I don't even go by the DIC - it's always way off. You need to fill up several times at the same station, on preferrably the same pump, so when the pump kicks off you know it's filled up the exact same amount each and every time. Then of course divide miles on your trip by gallons - but this only works if you remember to reset trip upon fillup.
My DIC says 14.7, because it's factoring in all the times I've towed cars & trucks with the car hauler. No trailer, I get 15.5 -15.7 consistently, with '07 5.3 flex, 4x4, 4L60E tranny, w/ 3.73 G80 rear. Winter blend fuel knocks 1 mpg off that or more.
Another factor is where you live. You wouldn't believe what some states pass off for fuel. MA offers you no choice but ethanol-diluted fuel. It's supposed to be for "clean air", but think about it - millions of vehicles getting 2-3 LESS mpg results in more gasoline tax revenue for the state, and a windfall for the oil company. Your selling cheaper fuel for the same money, & "cutting" it with ethanol - it's basic theft, but nobody says anything about it because the money rolls in.
It's posted on the pump as "10%". That kills your mileage BIG time. Now, with the flex engine, you have the capability to see "alcohol percentage" with a scan tool. I've never run E85 in the truck in the 5 years I've owned it, yet, I've seen alcohol percentages range from 15% all the way up to over 20%!! I can feel seat-of-the-pants power loss when I get an exceptionally crappy 20% ethanol batch. Mileage will also drop to around 13 mpg. This is also why my business is getting away from automotive repairs and doing more motorcycle, boat, lawn equipment repairs -- that percentage of ethanol wreaks havoc with small engines. Clogged carbs, and in worst case, seized engines that were jetted for normal fuel.I clean probably 100 carburetors per season, including my own ... and I drain them! The fuel is garbage here.
    lanaderay
    lanaderay
  • Who's Online   3 Members, 0 Anonymous, 1,552 Guests (See full list)
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
