VIN Details
Looking at an ad for a 2000 Silverado for sale, does not have pics nor does it say if its a ext cab or reg cab. Can someone look at this VIN and determine which it is? thanks in advance as always. 1GTHK33R1YF438382
Heres what the build sheet looks like.....
GM Vehicle Inquiry System
Vehicle Build
VIN :1GTHK33R1YF438382
Merchandising Model :TK30943
2000 CLASSIC SIERRA 3500 4WD
Gross Vehicle Weight Rating : 4177 kg (9210 lb)
Order Number : BWSRD4
Build Date : 10/22/1999
Build Plant : 1YF43
OPTION CODES:
AE7 - FRONT 60/40 SPLIT BENCH SEAT
AG9 - 6-WAY POWER SEAT ADJUSTER
AJ1 - DEEP TINTED GLASS
AM7 - FOLDING REAR SEAT
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR-KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
CMD - ASSEMBLY PLANT - FLINT, MI
C6W - GVW RATING - 9,200 LBS
C60 - AIR CONDITIONING-FRONT
DD7 - ELECTROCHROMATIC ISRV MIRROR
D48 - DUAL ELECT REMOTE CONT MIRRORS
E63 - WIDESIDE BODY
FE9 - 50-STATE EMISSIONS
FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ - RH
GT5 - REAR AXLE - 4.10 RATIO
G80 - LOCKING REAR DIFFERENTIAL
JB8 - HYD POWER DISC/DRUM BRAKES
KNP - H.D. TRANSMISSION OIL COOLER
K34 - ELECTRONIC SPEED CONTROL
K60 - ALTERNATOR 100 AMP
L31 - VORTEC 5700 V8 SFI GAS ENGINE
MT1 - 4 SPEED AUTO TRANS W/OVERDRIVE AND ELECTRONIC CONTROL
NA4 - EMISSION SYSTEM-HEAVY DUTY
NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHL
NZZ - OFF ROAD - SKID PLATE
N33 - COMFORTILT STEERING WHEEL
P06 - BRIGHT METAL WHEEL TRIM RINGS
R04 - SINGLE REAR WHEELS
R6J - CUSTOMER DIALOG NETWORK
SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS
UP0 - ETR AM/FM STEREO,CD/CASSETTE WITH THEFT LOCK, AUTO TONE CONTROL,SEEK/SCAN, AND CLOCK
UQ3 - ENHANCED PERFORMANCE SPEAKERS
U01 - ROOF MARKER LAMPS
VB3 - CHROME RR STEP BUMPER
VK3 - FRONT LICENSE PLATE MOUNT
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE
V73 - STATEMENT OF CERT. U.S.
XHH - LT245/75R16/E ALS BL TIRES-FRT
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLT EQUIPMENT / DECOR
YHH - LT245/75R16/E ALS BW TIRES-REAR
ZHH - LT245/75R16/E ALS BW TIRE-SPR
ZQ3 - TILT WHEEL AND SPEED CONTROL
ZY1 - SOLID COLOR
Z82 - HEAVY DUTY TRAILERING EQUIP.
Z88 - GMC TRUCK NAMEPLATE
1SC - MARKETING OPTION PACKAGE
1SZ - MKTG OPTION PKG DISCOUNT
11U - COLOR-PEWTER MET.
52D - NEUTRAL - CUSTOM CLOTH
52I - LT NEUTRAL INTERIOR TRIM
6GK - SPRING COMPTR SELECT FRT LH
7GK - SPRING COMPTR SELECT FRT RH
© 1998-2005 General Motors Corporation. All Rights Reserved.
Vehicle Build
Build Plant : 1YF43
OPTION CODES:
A31 - POWER WINDOWS
E63 - WIDESIDE BODY
SLM - STOCK ORDERS
ZY1 - SOLID COLOR
I actually copied the wrong VIN. This is the one I am looking at. 2GCEC19V9Y1353161 .
Thanks!
Here ya' go...........
Vehicle Build
VIN - 2GCEC19V9Y1353161
VEHICLE BUILD
Merchandising Model : CC15753 -2000 SILVERADO LS 1500 PICKUP 4-DR
Gross Vehicle Weight Rating : 2815 kg (6207 lb)
Order Number : CHWW3T
Build Date : 04/25/2000
Build Plant : 2Y153
OPTION CODES:
AE7 - SPLIT BENCH RECLINING FRT SEAT
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING
B33 - REAR COLOR KEYED FLOOR MATS
DK7 - INTERIOR CUSTOM ROOF CONSOLE
D48 - ELECTRIC EXTERIOR MIRRORS
EVA - EVAP EMISSION REQUIREMENT
E24 - DOOR SIDE CARGO, HINGED
E63 - FLEETSIDE BODY
FE9 - FEDERAL EMISSIONS SYSTEM
GU6 - REAR AXLE 3.42 RATIO
JC5 - 4 WHEEL POWER DISC BRAKES
K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
K68 - 105 AMP DELCOTRON GENERATOR
LR4 - VORTEC 4800 V8 SFI GAS ENGINE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NP5 - LEATHER WRAPPED STEERING WHEEL
OSG - OSHAWA ASM PLANT
PF9 - WHEEL-16X7" CAST ALUMINUM
QNG - P235/75R16 ALS WOL TIRES
Q4B - 6,200 LB GVW RATING
SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER
UQ3 - ENHANCED AUDIO SPEAKERS
VB3 - CHROMED REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XNG - P235/75R16-106S ALS WOL TIRES
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YNG - P235/75R16-106S ALS WOL TIRES
ZNG - P235/75R16-106S ALS WOL TIRES
ZY1 - SOLID PAINT
Z83 - SOLID SMOOTH CHASSIS PACKAGE
1SB - OPTION PACKAGE 02
1SZ - PREFERRED EQUIPMENT SAVINGS
12D - GRAPHITE CUSTOM CLOTH
12I - GRAPHITE INTERIOR TRIM
6ZP - LH-COMPUTER SEL SUSP
7ZP - RH-COMPUTER SEL SUSP
74U - VICTORY RED
Vehicle Build
VEHICLE BUILD
Build Plant : 2Y153
OPTION CODES:
A31 - POWER WINDOWS
SLM - STOCK ORDERS
YE9 - SILVERADO
ZY1 - SOLID PAINT
74U - VICTORY RED
THANKS!!!!
And, when skimming through the classifieds (as I did ALOT last summer), you can save a bunch of time by knowing how to read a VIN. It's easy. For these trucks:
The fifth digit refers to whether it's 2WD or 4WD. (C = 2WD) and (K = 4WD)
The sixth and seventh tells what bodystyle the truck is. (14 = regular cab) (19 = ext.cab) I'm not sure what the number would be for the newer crew cabs, as I wasn't looking at anything that new.
The eighth is for the engine. (W or X = 4.3 V6) (V = 4.8 V8) (T = 5.3 V8) (Z = 5.3 V8 Flex Fuel)
2GCEC19V9Y1353161
Whats the breakdown on the other digits?
Vehicle Build
VEHICLE BUILD
Build Plant : 2Y153
OPTION CODES:
A31 - POWER WINDOWS
SLM - STOCK ORDERS
YE9 - SILVERADO
ZY1 - SOLID PAINT
74U - VICTORY RED
Is the tool you used for that lookup something the average Joe can use or is it something restricted?
Thanks,
Daddy
Its restricted. Its for us GM dealers,Its called "GM-DealerWorld".
2GCEC19V9Y1353161
2=CANADIAN BUILT
G=GENERAL MOTORS
C=CHEVROLET TRUCK
E=BRAKE SYSTEM: HYD. 6001-7000LBS.
C=LINE CHASSIS:FULL SIZE TRUCK-TWO WHEEL DRIVE
1=SERIES:1500 1/2-TON
9=BODY TYPE:EXTENDED CAB
V-ENGINE:LR4 4.8 V8 "4800" VORTEC SFI GAS
9-CHECK DIGIT
Y=MODEL YEAR:2000
1=PLANT CODE:OSHAWA,ONTARIO CANADA
353161=PRODUCTION SEQUENCE NUMBER
MS3DALE, If you have the time, could you look up my vin? Its 1GETEK14T53Z243118. Thanks.
You had one too many digits in your VIN,but I figured it out....
Vehicle Build
VIN 1GTEK14T53Z243118
VEHICLE BUILD
Merchandising Model : TK15703 -2003 SIERRA 1500 4WD REG CAB PICKUP
Gross Vehicle Weight Rating : 2906 kg (6408 lb)
Order Number : FVRZC2
Build Date : 01/23/2003
Build Plant : 13Z03
OPTION CODES
AE7 - BENCH SEAT-UPLEVEL CUSTOM CLOTH
AG1 - POWER DRIVER SEAT ADJUSTER
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
A31 - POWER WINDOWS
B30 - UNIT PRODUCED WITHOUT: COLOR KEYED FLOOR MATS
B85 - BLACK BODYSIDE MOLDINGS
CJ3 - AIR COND., DUAL ZONE MANUAL
C49 - ELECTRIC REAR WINDOW DEFOGGER
C7H - GVW RATING - 6,400 LBS
DF5 - ISRV MIRROR W/COMPASS & TEMP
DK7 - CUSTOM INTERIOR ROOF CONSOLE
DL3 - EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL &GROUND ILLUMINATION
E62 - SPORTSIDE BODY
FWI - ASSEMBLY PLANT, FORT WAYNE, IN
GT4 - REAR AXLE - 3.73 RATIO
JC3 - 4 WHEEL ANTI-LOCK DISC BRAKES
KUP - THROTTLE CONTROL ELECTRONIC
K47 - HIGH CAPACITY AIR CLEANER
K68 - ALTERNATOR 105 AMP
LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NC8 - CALIFORNIA ULTRA LOW EMISSIONS
NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE
QC3 - POLISHED ALUMINUM WHEELS
QGC - P265/75R16 ALT BW TIRES
R6J - CUSTOMER DIALOGUE NETWORK
R9Z - POMS EXPEDITE-SOLD ORDERS
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
T96 - FRONT FOG LAMPS
UB1 - AM/FM STEREO W/CD, CASSETTE
UK3 - STEERING WHEEL RADIO CONTROLS
VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER
VG8 - BUYER NOTICE LABEL
VP6 - NOISE CONTROL
V22 - CHROME GRILLE SURROUND
XGC - P265/75R16 ALT BW TIRES
YA7 - CALIF. ASSY. LINE EMISSION TEST
YE9 - SLE/SLT DECOR
YF5 - CALIFORNIA EMISSIONS
YGC - P265/75R16 ALT BW TIRES-REAR
ZGC - P265/75R16 BW SPARE TIRE
ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE
1SC - SLE DECOR INCLUDES: AIR COND., DUAL ZONE MANUAL CRUISE CONTROL REMOTE KEYLESS ENTRY W/ALARM POWER WINDOWS & DOOR LOCKS AM/FM STEREO W/CD REAR WINDOW DEFOGGER POWER HEATED OUTSIDE MIRRORS DEEP TINTED GLASS ISRV MIRROR W/COMPASS & TEMP ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE
1SZ - PKG DISCOUNT
6YH - COMPONENT FRT LH COMPUTER SEL
62U - CARBON METALLIC
69D - DARK PEWTER CUSTOM CLOTH
69I - DARK PEWTER INTERIOR TRIM
7YH - COMPONENT FRT RH COMPUTER SEL
    LarT-26
    LarT-26
  • Who's Online   5 Members, 1 Anonymous, 645 Guests (See full list)
