Gm Performance Cat Back 2007-2009
New in box GM 17801989 Performance stainless exhaust system2007-2008 Cat-Back Exhaust System - Performance, Single Exhaust, Chevy Logo on Tip, Crew Cab, 5'8" Short Box and Extended Cab, 6'6" box
Constructed of T-304 stainless steel with free-flowing mandrel bent tubing. Features semi-polished muffler that meets all Federal decibel requirements. Performance-provides aggressive growl. Exhaust tips are welded to tailpipe.
selling for $550.00, prefer local pick up because of size of box, but will ship. add for shipping cost.
located in Jackson, New Jersey.
Three things.....
First,You might to post your location for those who might be interested.
Second,GM does not have a performance exhaust system for the '09s,The system you have will only fit the '07-'08's due to a design change on the '09s. You also might want to post the GM part number of the system you have.
Third,Welcome aboard!! :P
New in box GM Performance stainless exhaust system2007-2009 Cat-Back Exhaust System - Performance, Single Exhaust, Chevy Logo on Tip, Crew Cab, 5'8" Short Box and Extended Cab, 6'6" box
Are you in Florida?
No problem,I thought it was a 17801989 from your description.
Just to let you guys know.....That system lists for $900.00 new from GM,and has a dealer cost of $630.00,So $550.00 is a deal :P
Is this compatable with the 6.0? It seems they only list it for the 4.8 and 5.3.
None of the GM systems are listed for the 6.0. I found a great deal on a GM system at one point and passed on it because I have the Vmax. I think it would probably work, but I am afraid of the amount of drone it may have. The 6.0 is much more prone to drone then the 5.3.
I haven't seen any for the 6.0 either, I was more concerned with connections and if there were any flow issues due to a bump in size with the motor. I was willing to accept the drone due to the fact I'm pretty close to buying a magnaflow...if it's too bad I'll have Justin turn off afm when I get my tune... :cheers:
My corsa exhaust was listed for the 4.8 and 5.3... I gave it a shot with no drone. Very happy with the choice. :lol:
Corsa or borla make the exhaust... Can't go wrong with either one. :cheers:
Correct me if Im wrong but isn't the only difference between the 08 and the 09 the flange where it bolts up? if so, why not just weld it in place?
Is this similar to the corsa sport exhaust?
Borla is who makes the GM performance exhaust for the '07-'08's GMT900 trucks.
Well I've never compared,or listened to them "side-by-side" but I'd say they sound similar,I'm sure someone else could chime in if they've ever listened to both side by side.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,668 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
