How-To: GMT800 Vent Valve Solenoid Canister Location.
Hurl300
I have codes P0449 and P0455 that have come up due to a check engine light. (vent valve solenoid and emissions evaporator) How do I go about fixing them? I started with a new gas cap and that didn't work. And yes, I am one of those guys that like to top the tank off. I have since learned that is bad Ju Ju with these newer vehicles. I have a 2005 Silverado.
  • Replies 41
Thanks for the info. I have printed the 2 pics that were in the forum and have also seen the info provided about the price difference in the part numbers from a 2005 GM pick-up part at $160.00, Delco part $100.00 and the same part for a 2006 Suburban at $24.00. If the Suburban part and my 2005 Silverado part are the same, I will opt for the $24.00 part. Again thanks for the info.
Go with the $24 part. I followed the advice from Poster "odayflor" from the forum link above. I cross referenced GM part # 2593271 to AC Delco part # 214-2149. I bought the replacement from Advance Auto Parts for $22.99. They have it listed as an EGR valve. It is the exact replacement for the evap vent valve on my 2005 Silverado Crew Cab. I got four years and 46,000 miles out of the OEM part, I don't see any reason to "upgrade" to GM's modified part with the remote filter for around $150 more than the direct replacement. Below are some photos of the parts.
The first image is of both the old (left) and new (right) vent valve/filter units. Even the part numbers imprinted on the plastic housings were identical. The second image is the new vent valve/filter unit installed on the truck. I could not reuse the hose to the charcoal canister because it was too brittle. I replaced it using a short section of 5/8" heater hose to make the connection. All in all, it was less than a 30 minute job.
I am glad to see everyone taking advantage of my posts, and adding to it with photos and advise...My solenoid went bad after @ 45,000 miles (out of GM warranty of course). I researched the situation on the net for months before fixing it, because I just couldn't stand the idea of spending over $150,00 for a part that looks like it should cost $20.00. And to boot, the supposed $150.00 part was a dealer only part number, not available at the local parts stores....Then one day, after wondering if I would ever bring myself to pay that kind of money to get that stupid light to go off (after all it wasnt effecting the engine or my fuel mileage at all) I crawled under my 2006 suburban to see what kind of system it had under it. Low and behold, same identical part....For kicks, I called the nearest Chevy dealer, to see if they were showing the same $150.00 replacement, in fear that I would soon own two trucks with the same problem. To my surprise, the Chevy parts computer showed a direct replacement, with the exact same part for @ $22.00. Went and got it.Put it on, and it worked(of course it did, it was the same part). Read the posts above, because you will have to get a short piece of hose, and replace the brittle heat shrink one that was origionally attached to the solenoid, as seen in the above photos......
Good luck everyone...Lets get the word out, and Force Chevy to rethink the way they do business....After all, they are now the "NEW GM" right????
Glad to see that someone may have already found a solution to this problem. I have a 2003 Silverado. I too am guilty of "topping-off". I'm getting both PO449 and PO455 codes. How do I ensure I'm getting the right part? I'd obviously like to get the $22 version since the dealer just told me it's $80 to scan it and then depending on the issue up to $500 to fix it. Please let me know if you need further information. Thanks in advance, Brian
  • 3 weeks later...
Using the part from the Suburban was a great idea. Did the repair in about 30 mins, saved me almost $300 if I went to the dealer. Check Engine Light went off when I was driving to work the next morning (10 miles after the repair).
I just went through this exercise since I was getting code (P0449). Thanks to all the posting I was able to figure out what was wrong.
If you are experiencing this situation wit code P0449 check your gas cap first replace if necessary.
Otherwise it is a well know issue that the EVAP Emissions Canister (the one under neath the spare tire...I have an 07 Avalanche LTZ) is the part the need replacing. I have about 61,000 miles and this canister was giving me issues since I would clear the code and it would come back up.
Go to the Dealer and ask for part 25962086 ($27.19 without the tax) and repalce it underneath the truck...it should take you about half an hour tops and tha includes putting down the spare tire.
If anyone has questions I will more than happy to help.
  • 1 month later...
Is the replacement part still working? Also I noticed the number stamped on the 2 solenoids were different 1525C on the bad one & 2309B on the new replacement solenoid. However the number stamped on the filter cartridge, that the solenoid is attached to, is the same on both. I don't know if these numbers mean anything?
I do appreciate all the information!
I did the same thing ..cross referenced the other part WAYYY cheaper and mine went after 104,000 miles
2004 sierra
:D +1 i did it too, works great havent had a problem yet :D
  • 2 months later...
I just wanted to add this in this thread:
My solenoid is different. Apparantly there are two different flavors for this part. I had the square one. I was able to buy the exact same solenoid that came off from the dealer, but it was ~$90. I just wanted to make sure that I was getting the right one, the round one will not fit my rig.
My 2000 is the square one as well. When I popped this code a while back, I read the TSB on it. The cause was potentially dust plugging the vent solenoid so I figured what the heck, if I may have to buy a new one anyway, I might as well see if I can fix it myself. Well, I took it out, took it apart, blew all the dust out of it (a lot), put it back together, put it in, and NO CODES - Fixed. Took 1 hour.
It's easy except for the devil clip that holds the vent tube to the solenoid. I tried to take mine off and clean it a few months ago but the code came back in. It took me a good while to remove the tubing from the solenoid due to the tight space. You really have to squeeze the tabs and twist. Funny thing is that the new solenoid came with a new piece of tubing but you cannot remove the old tubing due to it being clipped down above the gas tank. I had to remove the new solenoid from the new tubing and re-use the old tubing. Holding it with both hands I could just barely get the new tubing off. It is really difficult to separate.
  • 3 months later...
where did you get that part from. I check Autozone and O'Reilly's and they didn't have it. They all said for me to go to the Chevy dealer.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
