Removing rear Panels
I wanted to know how to remove ths front and rear door panels to install new speakers in my 99 Seira ext. cab pickup?
Front Door:
Starting from the top of the door,
1 Carefully pry off the triangle piece opposite the mirror.
2 Carefully pry off the lock cover from the side facing the rear of the front door
3 Remove the screw at the base of the pull handle.
4 Pull up (starting on the outer edge) the window/electric lock control panel and disconnect the control panel. The second screw attaching the door panel is here.
5 Remove the door handle bezel. Pry by the base of the handle and work your way around.
6 Lift entire door panel straight up as far as it goes. Pull towards yourself to remove.
7 Disconnect the courtesy light
Rear Quarter
1 Remove rear seat. Fold seat and remove bolts to floor. Lift seat out.
2 Carefully pry out rear window molding
3 Remove screw in cup holder
4 Remove the armrest by pulling away from door panel
5 Remove sill plate on drivers side front door (pull up on snap retainers)
6 Remove the quarter panel trim screws
7 Remove the seat belt retractor
Rear Quarter door
1 Remove screw in cup holder
2 Remove door handle bezel. Pry from the rearmost part of the bezel
3 Remove door panel by sliding entire panel up.
Hope this helps
Carguru, do I have to remove the rear door panels to install new rear speakers, or can I just remove the factory speaker cover? I have the polk 4x6 Mombo. Thanks again.
Thanks for the help, I have everything installed, and the polk Momo sound sweet, along with my Infinity Kappas.
