Xenarc X2020 HID's
Machine
Took the leap and purchased some Sylvania Xenarc X2020 HID's for the Suburbans. Pardon the pun, but the difference is day and night. Installation and aiming took 30 minutes, and the fitment is perfect. These are true HID's made by Valeo Sylvania - the same group that makes OEM HID's for Dodge, Ford, Mercedes, Cadillac, Nissan, etc. This is not an HID modification to your existing headlamp; instead it replaces the entire unit with a self-enclosed HID package.
The cost: $425 per pair, w/ shipping
Ease of install: cakewalk
Performance: at least 3 times brighter than any halogen
Warranty: 1 year
HID bulb life: 3000 Hours
10 out of 10 for this upgrade.
  • 1 month later...
Agreed. I have them on my 2000 Z71. Very good light spread across the whole lane and shoulder.
I would recommend doing the 4-on-high headlight mod if you use HID's. Otherwise every time you turn off the brights, the HID's will have to restrike when the low circuit comes back on.
Warranty: 1 year
Does that replace both the low and high beams or just the low??
The whole headlight assembly gets replaced. The low beam is HID, and the high beam is still halogen, though mine came with two new silverstars for the high beams.
The Sylvania is the only DOT legal HID kit.
The way lenses refract light depends on the wavelength (that's how prisms work). HID's have much more blue light than halogens. The blus light gets refracted incorrectly by the front lens of a stock headlight. That's why the HID's don't have lenses, they have shaped mirrors, with no lens in the front cover.
If you put HID's in a stock holder, you'll be blinding other drivers, and won't have a sharp cutoff to aim them down.
Ok, stupid question I'm sure, but why are the high beams still halogen rather than HID as well? To maintain DOT approval??? :cheers:
Though a 4-HID system would be awesome.
Even in my wife's Lexus GS 430 the high beams are halogens and not HIDs.
:flag:
  • 1 year later...
hid lights do not project the light distances that a conventional filament bulb can. i watched the Motor Trend tv show when they tested them.
Ok, stupid question I'm sure, but why are the high beams still halogen rather than HID as well?  To maintain DOT approval???  :driving:
i think this is true unless you have projector lamp headlights.
  • 1 month later...
  • 1 month later...
One of the reasons HIDs are not usually installed in high beams is cost.
The other issue is startup time-the ballasts are not made for flashing the lights, they are made to be switched on and left on. Most HIDs have a warmup time during which the output stabilizes. BWM, for one has a different setup for their HID systems, where the lights are powered up partway all the time, so they can be flashed. This requires computer controls, AFAIK, to keep the voltage correct.
On top of that, if you have HID low beams, and they stay on with the highs, you don't need more than halogens for high beams, especially if they are focused for viewing down the road.
  • 3 weeks later...
  • 4 months later...
Warranty: 1 year
Dont want to speak for him, but :cool: that kit is low beam hid and high beam silverstar halogens which match the color of the hid output. This looks like a really nice kit as it includes completely new housings that are designed for the hid light rather than the old halogen assemlies.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
