Tire Problems on 05?
I was just wondering if anybody has had any problems with tire wear on the bridgestone duehler a/t's? I have an 05 silverado and my front tires are wearing funny. They are wearing like a sawtooth from front to back, each lug is wearing more on the back than the front. Anyone else having this problem?? :rolleyes:
I had a wear problem on my Goodyear stockers, they cupped real bad running at 35 psi. Run 'em around 40 now, seems to have evened things out over 10k miles. First thing to try is adjusting the air pressure.
My tires on my 05 are wearing the same way. Its called feathering, and usually a result of toe being out from alignment. I jacked up my Tbars a couple of months ago and got the alignment done. I have not seen the wear get any worse but to be honest with you I have noticed a few trucks with this wear. Not sure if its inherint on them or just come from the factory with alignment out.
I had similar wear on my stock tires also. I got an alignment when I got my new tires and it was off a little but when i asked them about the wear on the old tires, they said they doubted what was off would have caused that (sorry don't remember off hand what was out of alignment).
I have not noticed any wear on the new tires, so i'm hoping it was just something with the crappy OE bridgestones.
Rotating your tires every 6000mi is the key to good tire wear. I have had Bridgestone OEM tires on my last 3 trucks and have gotten over 50K with even tread wear just by rotating.
Had the same problem on my 04' took it in and they re-aligned the front end under warrenty and rotated the tires a 7k no problems sense. :rolleyes:
i've noticed the same wear on mine...i've got 10000 miles on now and rotated at 5000 and will again real soon here...the truck doesn't vibrate or pull either
I called the dealership today, where i know the service manager, he said that GM knows about this problem, it is a defect in the oem bridgestones, at the time GM is telling the customers to keep driving them and they are supposed to be doing a recall or something like that on them. He went ahead and set me up with an appointment to check the alignment anyways just to be sure. He also mentioned something about bridgestone was trying to manufacture enough to replace the faulty tires. Just for the record the truck only has 3300 miles on it and its this bad already.
This is the reason why as soon as I got my truck the Bridgestones came off and Goodyears went on!!
I don't like Bridgestones at all and have heard a lot of bad stories on them,Even the so called "best tires in the world are the REVO's" that a lot of guys on here swear by,I've heard a lot of horror stories on them also.
And you definetly need to rotate the tires on these trucks every 3 to 4,000 miles,anymore and sometimes the wear is so bad you can't "even-it-out" by rotating them around.
6,000 would be the most I would go but even that is a little to far for me.
I agree driving on these stocker pos bridgestones has scared me away from that brand for good, i dont care how many people praise those revos i just dont like the bridgestone brand at all!Bfg ko's imo are the way to go and cant wait for them to show up at the tire store damm things are on back order from bfg!I cant wait to have a tire that doesnt feel like it's going to fold under itself around corners like these duelers do and not to mention have traction in the snow.
Could you guys please document your recall sources, or call-for-recall sources.
Thanks! A URL would be great...
Absolutely.
Toe has been a problem on these too, but even with a good alignment, the front tires are subject to wear unevenly.
Never heard anything about specific tires being recalled for any reason.
    • We did 250 on our tractors until we switched to Amsoil. We doubled after that.
    • When I was there, most to all did not have an hour meter. They just did 5000 miles on regular vehicles and 3000 on police stuff. The modern oil change monitors should take into account engine hours, weather, etc. I don`t use the monitor on my stuff. I pull the stick, look at it, smell it, rub it between my fingers, etc. That`s my oci.   I have had many engines. Some bracket race. No problems doing things my way. I was in the mechanic business for 30 yrs or so. I still do things the old school way. Don`t care who laughs at me.   Understand, I was in the main shop. We didn`t do oil changes or tires. We had a service station for that. I don`t remember the hours they used for tractors, lawn mowers, etc. Something in my head says 250 hours.
    • I don't know how far back vehicles had hour meters, be it driver accessible or diag accessible but was wondering if there was any rule of thumb your shop came up with in regards to an hour limit on engine oil regardless of the miles on the oil.    I know with construction or farm equipment its almost always based on engine hours for maintenance scheduling as no other metric really applies other than a seasonal time limit that one self imposes on items like engine oil.
    • I'm not sure what to say on that mess but I will say that is an odd thing for that mechanic to speculate on as per assuming its been run out of oil a few times as the odds of that engine having instead piled up with a complete seizure would be very high if such events had actually taken place. However there is nothing saying that the oil has ever been changed although once again, what filter was on that engine as that would tell part of the story if its possible to figure out if its a factory installed filter or not. Too many items unknown and a lot of speculation, but regardless of that its one fubared mess that is mind boggling to see for a vehicle that new and its hard to imagine how it ever made it that far in life looking at the top of the engine.    His scanners, I've watched him before here and there and I'd have to say if I recall correctly that some of his scanning equipment is one or two steps up from a child's Exo Sketch 😋
    • I agree. That`s a LOT of sludge for 12,000 miles. I tossed that out here since this is an OCI thread. There`s tons of people here that do not post.   I used to work on a city fleet. That includes police cars and fire trucks. Lesson is, not to only use the odo for oci. A police car has a ton of hours on the engine for the miles it shows. And, not just idling, directing traffic. They beat on these things.   Course, since it is a Kia, they were gonna use the "100,000 mile warranty" for their OCI.😉
