E-85 Refueling Events
I am going to start a little thread on E-85 compatible vehicle refueling and hope on of the admin's will pinn it. The refuel info should be in your owners manual but I'm going to explain why. Improper fueling events cause hard starts, missfires, rich or lean codes and in extreme conditions can cause a no start. As a technician I have seen a bunch of problems created by improper fueling. If a tech hasn't been burned by it a few times checking your content may be last on his list creating comebacks and unhappy customers. This applies to all GM E-85 compatible vehicles built 2005 to present and a few built before that, they all use the same refueling procedure.
The first GM vehicles that were E-85 compatible used a fuel content sensor that measured fuel content as it was being used. This was a very efficent way to measure content but the sensor also needed to be a computer to do some major calculating on the fly. As a result they were about $400 a piece. GM decided to go the way of most other manufacturers to cut costs and do away with the sensor and go to a learn algorithm. It is very efficent as long as refueling is done properly. I wish we would make salespeople go over the procedure to head problems off at the pass but that's another story alltogeather.
First let me (try) to explain a little about what the vehicle is doing. When refueling has occoured the PCM or ECM depending on vehicle basically says "we have new fuel" and for the next few miles (distances vary but I'll give you the recommended later) it starts adjusting fuel injector rates and spark timing and watches what happens based on a few of the sensors and uses some crazy math to figure out what is being burned. Lets say you have half a tank of E-10 and add 1\4 tank of E-85, the vehicle sees that since the last drive cycle there has been a 25% increase in fuel volume. It starts varying, watching and calculating and eventually will come up with a tank content of something like E-40 (I know someone is checking my math, don't bother it's just an example I know its not accurate). The vehicle is not measuring what is in the tank it is measuring the difference of what it knew was there and what it calculates was put in. If it gets one calculation wrong every fill after that will be exponentially wrong as well. If it thinks it's burning E-10 and it actually is burning E-40, since the volitility is different there will be problems.
On to refueling events. In order for the PCM to watch for one and then adjust for it some things MUST happen. First the key MUST be off. This is a good practice for all vehicles not just E-85 compatible. With the key on evap testing may happen and obviously with the cap off the vehicle will see a large leak, as I'm sure many of you know this gives you a check engine lamp on a vehicle that may be perfectly fine. I'ts especially critical on E-85 vehicles because of the prementioned way the PCM is doing calculations. I know the kids like the radio on and you want to listen to the rest of that song or the ball game, so do I, but you shouldn't. Next the fuel level change must be 3 gallons or more, I recommend more just to take slightly wrong fuel level sensors out of the equation (that gives me another idea, why using top tier fuel protects that sensitive level sensor). Finally The vehicle must be given enough time to make the calculations, our data says and I quote "usually by the time 7 miles of operating temperature driving has been completed" so it's not the same every time it's just a guideline. Basically don't go to the gas station a block away while the vehicle is cold and go to the store 2 blocks from the station the new fuel will not be learned and it will not pick up where it left off, once the learn drive cycle is done it is done. The vehicle needs to be in closed loop for any adjustments to be made and closed loop doesn't happen in the first few minutes of any given drive cycle. Once in closed loop it will take a few minutes for all of the calculations and fine tuning to complete.
You may be asking why not just calculate it all the time and do away with the refueling events? Simple answer, it's not efficent, fuel mileage would suffer and it takes quite a toll on processing or so we are told, sounds viable to me and I couldn't change it if it were not so why bother asking why. If the calculated content is wrong it goes something like this. Vehicle comes in and the complaint makes me think fuel quality or content might be an issue. I use the Tech-2 to look at what the PCM has calculated it to be, then take a fuel sample and visually check for water and impurities then I check the actual content. If it is more than 15% off then the tank MUST be dropped down, emptied and dried out and an initial refuel event needs to be done. If that fuel is not E-10 or E-85 it must be disposed of. Using a blend like E-40 for a refuel will not work, you just lost 25 gallons of gas. So to sum it up refuel correctly.
  • TURN THE KEY OFF
  • USE MORE THAN 3 GALLONS
  • DRIVE 7 MILES OR MORE
This all is not an issue if you never ever from the first mile ever use anything different but if you use something different one time proper refueling needs to be done from that point on.
  • Replies 66
Thank you Mike for the great info. I never knew about any of that. The first 3 tanks in my truck were gas and then I switiched over to E-85. :fume:
I've been using only E-85 for about 3 months now and love it. I don't mind the drop in MPG as long as I just keep telling myself I'm helping the American farmer, the enviroment, and keeping the money from the big oil companys.
I will keep the refueling rules in mind from this point on. :thumbs:
Have you heard of this deal that some guys are talking about E-85 washing the cylinder walls of oil, and that GM knows about there being an issue with this and will just replace engines if they need to?
Is there any truth to this?
Thanks for your help....
I have not heard about that yet.
Great Information. I did not know this great to know for my 08 Tahoe still waiting to get through the reg gas then switch to E-85. I will pin the topic!
  • 7 months later...
Could this explain why I can't get any better than 16 MPG out of my 07 Avalanche? I never leave the key on but I may have driven less than 7 miles after adding E85 to a tank with E10 in it. I have been disappointed in the MPG of this truck from day one. Hell, my 04 Av got better mileage than this one. I am the same person doing the same job and driving the same places with the same driving habits. I typically got 16 out of the 04. This new truck typically gets 13. I recently took a 400 mile road trip on nothing but 70 MPH Hwy. I reset the computer at the start of the trip and after that trip I had averaged 16 MPG.
I have a friend with an 07 Av and he always averages better than 16 MPG. He has never put E85 in his truck. His is 4WD mine is 2WD. I know driving habits play a big part but no matter I drive I can't get better than 16.
TIA,
Matt
Thanks for this info again but what a crock of shit this is to have to drive 7 miles out of one's way just to "safely" refuel.
And driving your truck to the moon isnt out of your way??? haha
But that was financed by taxpayers like you and me!
Too bad he didn't stay there huh? :happysad:
  • 1 month later...
Ok, so let's say you found this forum and this thread after you already improperly fueled and mixed fuels and now you only use regular pump grade gas (e-10). I have noticed less fuel economy than before, and when the traction control get's really mad (icy roads) when pulling away from a stop, I am pretty sure I hear backfires comming from under the hood.
Now what can I do to get the computer to start over with it's math?
"If it is more than 15% off then the tank MUST be dropped down, emptied and dried out and an initial refuel event needs to be done. If that fuel is not E-10 or E-85 it must be disposed of. "
Can I force an "initial fuel event"? I know that the last 20 tankfuls have all been E-10, so I am sure it is e-10 in the tank.
Thanks for the help
Fireman Ed
08 sierra crew
  • 1 month later...
I'm curious about this myself. I typically drive my truck on long trips and fill up .3 miles from my house so that I can start my next trip with a full tank. It sounds like I need to store my truck empty and fuel up before I leave rather than when I get home. That's not going to let me properly split gas costs with my buds!
Oh crap, what if I bought my truck used, and dont know if it ever had E-85 put in the wrong way before? Do I need do the relearn thing?
  • 3 weeks later...
I too am wondering this for future reference.
So how does the initial fuel event happen? You drain the tank, put E10 in and the truck now knows you have E10?
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 465 Guests (See full list)
