Brakes Dragging - Hydro Boost System
GMChris
2000 Chevy Silverado 2500 4X4 (6L Gas)
Brakes dragged, rotors got very hot.
All calipers replaced. Master Cylinder replaced. Brake fluid reservoir cleaned and dried. All brake lines flushed & bled. Power steering fluid flushed with one gallon new fluid. Steering works perfectly. (Always has)
With power steering system bled down, new master cylinder sits 1/8 of an inch (same as old one did) away from hydro booster flange due to the booster output push-rod extending out.
Master cylinder mounting bolts will suck it in when tightened but is this pre-loading my M/C and causing it to self apply the brakes?? What is the correct clearance between hydro-booster unit push-rod and M/C?
Is my Hydro boost the problem? There is no adjustment on booster output push-rods these days.
Brakes are fine until 15 minutes or so of driving.
Help!!!!
Help!!!!
Ok! I drove around for 1/2 hr today and the brakes began to drag harder & harder as the truck warmed up. I parked, then unbolted the NEW master cylinder (when I replaced it I totally bled the brake lines - used 3 quarts dot 3 brake fluid). Now with the master cylinder 1/2 inch away from hydroboost unit, all 4 brakes were still locked up. So HYDROBOOST checks out O.K!---- But brakes are still no good!!!! ABS malfunctioning? Possible water contamination spread to all the new parts I installed?.....LIKE THE ANDROMEDA STRAIN? HELP!!!! PLEASE!!!
I can't seem to find it but I seem to remember a recent post with a similar problem. Poster said a new hydro fixed it.
Mark
Thankyou so much for the great responses. I'm a Newby here. In my 50's and been working lots on cars/trucks all my life, so I may have alot to offer here as time goes by. I'm thinking the Hydroboost is NOT the problem since all brakes are dragging badly (to varying degrees) even when my NEW master cylinder is unbolted and pulled back from my Hydrobooster. I'm a little shakey when it comes to: a)Hydrboost Brakes, and b) ABS brake system. I am however an electronic tech. I'm now going to drive it 'till it's warm so the brakes drag again. Then I'm going to begin releiving brake fluid pressure on each circuit starting with the LH Fr caliper bleed screw & working back up the system towards the master cyl. I WILL NOT LET THIS DEFEAT ME!!!!! there are many, many similar posts with no solutions that satisfy my exact situation, but when I'm done I will post a "Problem w. Symptoms", and "Solution". I've read people's ideas about moisture, foriegn particle, and air contaminated ABS Brake Pressure Modulator Valves. Does anybody know if there's really any truth to this?
I wish I had some suggestions for you, but it's beyond me. But good luck!
Maybe try removing the ABS sensors to see if that makes a difference. It sort of seems like the brake fluid pressure generated during braking is not being fully released with each application of the brakes. So every time the brakes are used increases the base pressure in the system.
If your going to troubleshoot by loosening lines, why not start at the hydroboost first. It will effect all four wheels at once. I have never heard of the ABS causing 4 wheel lockup. Also if the ABS malfunctions, it should set a code.
Mark
Mark
As I wrote in my last post:
Mark
I don't know how to link the topic, but I found the one I was looking for. It's in the Heavy Duty forum. Feb.13 2009. Poster said brakes would lockup after a little driving, he would bleed off pressure at the master cyl then could drive a little more and it would repeat. He stated he replaced the Hydro-boost and his problem is gone. Also like I said, if it's the ABS you'll get a light and a code.
Mark
  • 5 weeks later...
It's been a while since my last post. I wanted to be sure my problem was solved. The entire repair job consisted of: Replacing all 4 brake calipers and pads. All 5 flex brake hoses. Master Cylinder. Master Cylinder reservoir - thoroughly cleaned/ dried. Brake fluid replaced. Power Steering fluid flushed and replaced (power steering pump operates the brake Hydro-Boost system). Well it turns out that after replacing the parts and examining the old calipers, 3 YES THAT's RIGHT....3 calipers had siezed within 9 days of each other. As all of the old flexible hoses actually checked out OK, the only reasonable explaination we could come up with is that due to an exceptionally long and cold winter (the cold due to global warming) there's been probably 5x more salt than normally used this past winter and it caused corrosion in the brake caliper piston bores.
    250.3k
    DjmFingerstylePlayer
  • Who's Online   4 Members, 0 Anonymous, 618 Guests (See full list)
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
