Vvme Hid Hookup
I'm about ready to hookup my VVME HID kit on the 99 GMT800. I'm looking at the instructions and the connectors.
It's not obvious which way the connector goes on the ballast. It can be made to fit either way.
Also, I can't see in the pictures in the instructions what the grommet they provide is for.
Any help would be appreciated.
Did you get a little carried away with the post button. :)
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
