The wires in the column are there you really just need the buttons harness that goes in the wheel and the black back cover with the cutout for the buttons. The easiest thing to do would buy a used wheel with the controls and just swap out wheels. From what I understand thats what most here have done who have made this mod!
  • Replies 42
Top Posters In This Topic
Were should i look for used wheel with controls. been looking on google still iam lost ..
Help!!!
I had found quite a few on http://www.car-part.com/. I searched under 08 Tahoe. I was going to order one, but one popped up over here for sale before I did.
Good Luck!
Galen
Thanks Galen,
I just put in dic switch and it works great. dealer told me when i bought the truck it would be $1500.00 and wasn't worth the price. I paid $80.00 and it was worth every penny. Next is the steeringwheel with the radio control knobs. I have only cruise buttons on mine at this time.
Thanks again for your help.
Jesse
  • 3 months later...
For those of you thinking about adding the switches with out swapping wheels, i'm in the process of doing this right now. Ran into a couple hurdles but so far so good. I made my own harness that plugs into the radio controls and used a dremel tool to cut the hole in the back steering wheel cover for the controls to fit into.
My harness does not have the plug for the radio controls in it so I'm going to have to splice 3 of the 4 wires. Here's where the hurdle comes in. My harness also does not have the light green wire in the main connector labeled "C" which is needed for the radio controls. I'm going to add this wire myself, but need to run to the dealership to see if i can find the aluminum connector that will fit inside the plastic piece.
I'll keep everyone posted on how this goes, so far so good.
Ok fellas, all done, SUCCESS! Works great!
Here's the finished product
did a little splicing, added the one wire that was missing cut a hole in the back steering wheel cover, and ta daaa its all done!
Congrats on the job. So the buttons are the only thing you bought, and adapted to your OEM pieces? I would also like to see a picture of the shroud if its not too much trouble.
Well i bought a few things, I bought the buttons, and the metal connectors i used to plug into the buttons. These connectors were pretty easy to find since all i needed was something that fit snugly onto the prongs inside the buttons. The connector that i needed for the plug that goes into the clockswitch was a different story.
I had a very patient parts counter person who looked for about 45 minutes for this very hard to find connector. This is the wire that is not included in our factory harness, so it must be added. It is the one that goes inside this plug (highlighted in red) The part number on this little connector was 15305174. I don't know if that is a GM Part number or a delphi part number, but hopefully it gets you started in the right direction. post-66063-1259816193_thumb.jpg
For the shroud, i took a piece of paper and traced the cutout for the cruise control side and then traced it onto the other side of the shroud. I'll see if I can get a picture tomorrow. The cutout isn't perfect by any means, but you cant really see it because of its location.
Here are the connectors I bought from the dealer. Soldered them onto the wire and then added some heat shrink tubing afterward.
After I added the heat shrink tubing, i pushed each wire I made onto the prongs inside the buttons. After I got them all pushed in all the way, i took some ultra black silicone and filled the rest of the cavity where the factory gm connector would go. I did this to lock the wires in place so that they wouldn't vibrate out or get pulled out accidentally.
Then I spliced the three wires i needed into the factory harness. Re-wrapped the harness with electrical tape and reassembled.
Edit: I belive the part number I listed above is a delphi part number
http://connectors2.delphi.com/dcsgdmcs/del...S01_S01.tif.pdf
Edited by TriumphoverU
Cool man, that info will definitely be useful for someone that hasn't done this mod. I myself went the other route, bought a used wheel ($80 on ebay, only it was gray and my interior is black) and had to paint the shroud to match. Thats why I would like to see yours, I just might decide to cut my original one and reinstall it for a cleaner look.
TriumphoverU -
Firstly awesome work. I am trying to do the same thing. I e-mailed my dealer to try and buy the wiring harness and radio switch and on top of quoting me astronomical prices (they won't sell the harness separate from the steering wheel) they also said:
"IF you are able to remove
the airbag without detonating it, there remains the issue of programming the
Body Control Module - the new additions will not be recognized and will not
function without the download from GM. The download itself will not take
unless it is registered by GM for a fee."
Is this a scare tactic? I gathered from your post that this was simply plug and play. Do you require a download? Thanks.
TriumphoverU -
It is a scare tactic, there is no reprogramming needed. Wire it up and go, simple as that.
    Tbhats2130
    Tbhats2130
  • Who's Online   2 Members, 0 Anonymous, 2,441 Guests (See full list)
