Cruise Control
well first off some info on the truck 2004 Suburban with about 130,000 miles on it, I was on my way home tonight and i was getting up to about 70 mph on the Highway went to set Cruise, nothing well tryed about 5 more time and Still nothing, I know on the way to the race track(that's where I've been all night) that it was working, used it for about 5-10 miles. well I got home checked the only fuse i could find for Cruise and it was fine. What should i look at next? kinda drawing a blank on this one.
Thanks in advance Robert
Check the rear lights. If the cruise is as sensitive as it was in my '02, one could be burned out and affect the cruise. Sounds weird....but worth a look.
Well I just put New L.E.D Tail light's on the other day. and it's been working fine with them till now. i checked all light's, all the lights in the rear are working. do you think the New L.E.D's Have anything to do with it?
Well I put the old tail light's back on and the Cruise still doesn't work. any other Guess's at this one? I went on a 200 Mile trip today and no Cruise Suck's!
Something new i found out is that if i try to use the Cruise right after i turn off the turn signal that it will work for about 5-10 sec's, do you think the New L.E.D's could have blown a relay or something?
