Badges And Decals....
I asked this question a few weeks ago, but now I can't find the thread anywhere (and I went all the way back to mid-May)....
I am looking at painting my truck later on, and after I'm done I want to put the badges and decals back on. Problem is.... I have no idea how to remove the badges without busting them, and then to put them back on.
It has been 16 years since I last did autobody. I don't think the badges go on the same.
Help!
They're held on with a double sided tape. A very good double sided tape. Your truck is new enough and the badges few enough that it may be easier to buy new badges.
The hard part is alignment when installing them. A friend of mine makes tooling for badge installation by dealers and makers. It's a pain to get all the dimensions right.
Two options to help with removal depending on how they are attached...
Where they have been applied with glue, not double sided tape, use the method below with caution...
You'll need a heat gun and plastic putty knife. Obviously you must be very careful using this method. Place the putty knife under the badge and apply pressure. Start working the heat gun over the badge and as the adhesive gets warm the knife should start lifting the badge. Keep working the gun and knife left to right (or vice versa) until the badge is off.
Where they have been applied with tape...
Take some fishing string and work it back and forth (sawing motion, top to bottom) from one side of the decal to the other. The heat generated by the line cuts through the foam in the tape.
Remove residue from both with some kind of solvent (goo gone, goof off, etc). Clay, seal then wax the area and enjoy.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
