Tpms Do I Have It
I just picked up a set of factory 17" aluminium wheels with tires from an 08 Silverado with 500 miles on them, I just installed them but my TPMS is not working.. How can I tell if the wheels have the sensors? My stock steel wheels were working fine with my DIC . Where are the sensors located?
thank you
The sensors are located on the end of the valve stem.
The sensors might have been removed from your take-off wheels.
thanx I will look at my stock wheels later today and remove them and install on my new wheels. Should be a easy swap right?
If the sensors are missing, the tpms will be in alarm, is that the case? If not, maybe all you need to do is go through the re-learn procedure.
You have to break down the tires to get to the sensors and mount them not very easy to do without th right tools.
wow so I have to break down my old tires then remove the sensors then break down my new wheels with tires and install the sensors then fill back up?
Yes. The tire shop tried to make me pay extra to swap the sensors off my old rims to the new ones. I did not pay. Hell all they had to do was unscrew from the old one and out it back on the new one.
Here is a pic of the valve stem
Certainly looks like the ones with the sensor.
The only way to know for sure if the sensors are still there is to break a tire down and look.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 952 Guests (See full list)
