Temperature
it has been really hot where I live. Im assuming that would definitely play a role in making it run hotter.
If the thermostat works properly, and the radiator is adequate, outside air temp has no effect. Most of the newer GMs I drive are just under the 210 mark. Those gauges aren't particularly accurate, the thing to watch for is drastic changes.
mine runs right at 210 on the gage also and we've had a very cool summer up here.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
