Exhaust Input?
what do u guys think of......
edelbrock shorty headers
to cut outs
into magnaflow hight flow cats
to dual flowmaster 40's thurnong out in front of right rear tire
and can someone tell me the pros/cons od short tube vs long tube headers
ok long tubes it is.... any idea for brands....
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
