Gmc 1500 Warm Engine Long Crank Time
I have a 2000 GMC SLE with 4.8 V-8.
If I wait about 1-1/2 second after turning key on before attempting to start, the engines starts normally when it is cold.
When the engine is warm I have had problems with long crank on warm start.
I have tried different techniques starting the engine after it is warm but continue to get much longer cranks before start.
Have checked fuel pressure, seems ok. Pressure peaks about 60 psig then falls back to ~55 psig.
Have read about the fuel pressure regulator problems others have discovered and noted in this forum and will check for a failed diaphragm.
I wonder if any other forum members have noticed similar difference between cold and warm engine starts that I'm seeing and found other problems to be the cause. Perhaps plug wires, computer, sensor in intake etc.
Thanks for any help.
I have to report the problem was the Fuel Pressure Regulator. When I pulled the vacuum hose off of the regulator gas spilled out of the hose.
After replacing the regulator truck starts normally when warm.
That would've been my guess based on a number of past posts. I had the issue on my 99 as well.
Yep, very typical/common problem on those trucks. Very simple to fix though.
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
