Custom Tuning
I think I'm going to go ahead and get a custom tune rather than a handheld programmer. After doing a lot of research I'll spend the same on a custom tune and keep my old pcm for what it costs for a good programmer. However, I have a few more questions. First off, if I keep my old pcm and tune a new one can you switch back and forth between the two without doing a crank relearn? I've been told you don't have to by the tuner but wanted to make sure. At first I wasn't going to keep my stock pcm but for $100 as might as well have it as a backup. Second, concern is with check engine lights. Say down the road I have a check engine light come on. I take it to the dealer and he scans it to look for codes. Does this reset anything? I've heard that people swap out pcm's to stock when they take it to the dealer for service because it may "reflash" the pcm and they will lose the programing. Another question is if you have a diagnositic code throw on the tuned pcm and then swap out for the stock pcm will it still throw the same code? And vice versa if you have the stock one in and swap the tuned will the trouble codes be the same? Lastly, I think I'll just do the 87 tune. I don't always have acess to 91 out where I live. I'm not looking to have a drag racer just something with more pep starting out any maybe pick up a 1-2 mpg if possible. Is this tune even worth doing?
well you can clear the Check engine light codes either way. If it it triggers a code tuned it will most always trigger the same code with the stock PCM as well. Most only put the stock PCM when they go back to the dealer for WARRANTY work only. The 87 tune you will notice a slight difference but not near as much as you would with the 93 tune. Once you put the tuned PCM in you will most likely not ever want to go back to the stock one. The truck is entirely a different animal when tuned. Yes you will pick up fuel economy as well IF you keep your foot out of it. Hope that helps.
You do the crank relearn 1 time and then the computers will know your engine's crank position and won't have to do it ever again.
How many of you guys that do tuning keep a stock pcm? Just curious?
Unless you're doing a tune with your own handheld, it's nice to have the spare modules. You can mail off your ECM if you want it re-tuned in the future and you can still drive your truck with the stock tune
So what exactly are you guys noticing after you get a custom tune? Acceleration improvement? Read about little better mileage gains. What about torque gains? Able to light the tires up?
I kept my stockers.
I notice the lack of most of the torque management and delay in opening the throttle plate, the trans shifts firmer and faster, the trans shifts earlier than stock under 50% throttle, shifts later more than 50%, I know there are some other things but can't think of them now. I saw no gain in milage. I have access to more of the power this truck was supposed to have from the factory. I can't light up the tires, I think you might have to do internal work to the engine to do that. My 0-60 time is still 10 seconds, I don't think there's anything that can be done about that without opening up the engine and replacing parts.
Well worth the time and money.
I kept my stockers.
You still can't light up the tires even after the tune? I thought removing the TM was really supposed to helpful getting the thing going. I'm planning on getting a tune, but I'm starting to have second thoughts. I'd like to gain some mileage and drivibility, but I'm starting to find more posts with people saying they aren't seeing significant gains with a tune alone. Most say they are happy with the tune so that's what confuses me!
The tune does a considerable amount, the engine doesn't have 600 ft-lbs of torque. There's a point where you need to dig into the engine. If you want to drag race your truck, you need to do some major internal work to the engine AND a tune. The tune frees up what the stock programming is holding back, but it's not going to give you more than the engine is capable of in it's stock form if it did, Comp Cams, Magnacharger, etc wouldn't be in business. Drivablility has increased significantly, the truck might actually have 315 HP but that's all it has. If you feel that everyone that is happy with a tune but doesn't see an extra 150 HP gained is full of it, then just drive your truck as is. Lighting up tires isn't the only reason people get a tune.
I have ridden in Darkanions truck.
It has 20 inch wheels and (I think) 285 tires on it.
It "WILL" light up the tires with no problem at all. :rollin::rollin:
Leaves a real nice smoke screen behind it. :rollin::D
Yeah that makes sense. I guess I wasn't meaning that I wanted to roast the tires off, but at least be able to break them loose so I feel like the tune was worth it! I don't mash on my stuff. From the info I've been gathering I'll probably wind up doing a tune. It's probably the best upgrade for the money.
A tune really woke my truck up. Definitely the best bang for the buck.
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 655 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
