Rear Fender Liners For 09 Silverado
I am looking to get some rear fender liners for my 2009 Silverado. Just wondering what is required to put them in and if it will be something I can do myself or if modifications will have to be made and will have to take to GM dealer to install. Any information or help would be appreciated
You can install them yourself. Most have put them on without removing the wheels. They come with some mounting hardware but they fit snug in the wells. Do a search as there are multiple threads on this, including other options such as spray-in bed liner or undercoating. You should find any other information to help with your decision. Good Luck.
I was intrigued by them, until I saw the thread titled Rubber..., search it, and for $15, and a little time, spray them with undercoating, and then "seal" them up with some satin black paint, and it looks amazing IMO
But if you still want the liners, it should be very easy
If you jack up the rear of the truck and let the rearend hang down they will slip on. A drill and a screwdriver is it.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
