Coolant Pressuring Up = No Leaks In Coolant System?
ra8643
Hello Everyone,
OK, so I have been trying to determine if my sludged oil may be coming from coolant leaking into the crankcase. I called my dealer and he said that Dexcool will not turn the oil gray - but sludge it up just like I was seeing.
Here is my question - I have opened the reservior several times hot since I changed the oil and added coolant. Each time it is pressured up. Does that mean that I don't have a leak in the coolant system (i.e. like a cracked castec head)?
Or does that not tell you anything?
Thanks,
Joseph
Doesn't tell you anything. I had a head gasket leak. Had coolant in oil and hot manifold gases pressurizing coolant system. Bad news either way. May not be your issue but something to consider.
Hello Everyone,
Thanks,
Joseph
Send a sample of the oil to Blackstone Labs and they can tell you what's going on with it.
Hello Everyone,
Thanks,
Joseph
Or, pull the valve covers and perform the visual inspection.
    Clark_Elite
    Clark_Elite
  • Who's Online   1 Member, 0 Anonymous, 213 Guests (See full list)
