2003 Yukon Xl: 4wd Not Working
Greeting all-
My folks have a 2003 GMC Yukon XL SLT with approximately 130,000 miles on it.
They called me and told me that none of the lights on the 4wd switch (auto, 2hi, 4hi, neutral, 4lo) light up and "service 4wd" is displayed in the driver's information center.
I told them to check the fuses, then replace the 4wd switch and get back to me. The new switch has been installed, but the indicator lights still don't turn on. However, they said the info center no longer displays "service 4wd."
Ideas?
Actuator switch. I had that go bad on my 03 causing the Service 4wd light.
Do you have a way to clear the codes? That too worked for me once or twice to make it work again.
That thought had crossed my mind, but would that cause all of the indicator lights to go out?
It does not indicate which mode it is in, nor will it switch out of 2wd.
Yes... it will. I had no lights on my switch when the actuator switch went bad. Just the Service 4wd. I got lucky more than once by just clearing the code, and starting the truck back up.
Thanks for the tip!
The actuator is GM Part # 26060073. I got this message on GMpartsdirect.com:
when replacing your original unit you will need harness part number 88959465 for 1500 & 2500's or 12376318 on 3500's when replacing the original unit. New unit must be wired up using new harness kit.(please check with customer service before ordering to insure you get the correct harness as olders models may differ.)
Again, the model year on this vehicle is 2003. Anyone on here had to get another wiring harness?
Also, can I get a pic of the location of the actuator? I'm sure I would not have a problem finding it myself, but this is my parent's truck and I live 1400 miles away...I want to make it easy on them.
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
