Ipod Install Into '93 Silverado.
This belongs in the Classic section, but I figured there's more traffic in here and it's a pretty interesting read. I take NO credit for this. My buddy did this all on his own, I just took some crappy pictures while he did it.
Basically, the pictures and description below show/tell you how to play your Ipod through the old GM factory radios with the cassette player. (Auto-Rewind FTW!)
What you'll need:
1. Standard double male ended 3.55 mm headphone cord. (Cut one end off, and strip the two wires)
2. Wire cutters/strippers.
3. 1/4" socket set.
4. Some electrical tape or heat shrink.
First, take off the dash cover. Pull the bottom out toward you, and pull down.
This is what you'll see.
Next use a 9/32" socket to remove the three screws that hold the tape player in.
A gentle tug, and she'll come right out.
Next use a 1/4" socket to remove the screws that secure the top cover of the player. There should be one on each side, and 3 or 4 in the back.
The cover come off sort of like this: vvv
Here's the harness you will need to deal with. Sorry for the crappy picture, but you get the idea. The wiring diagram in the Haynes manual says the wire you need are orange/white and white. Unfortunately, no such wires existed. With some probing with a test light, we figured out that the wires you need to cut are the 2nd and 3rd wires from the back (back as in back of tape player). Cut these as close to the harness as you can. Take the ends of the cut wires (the free ends) and connect them to the ends of the headphone cord. the wires are tiny, so we decided to solder them instead of wirenuts. In the picture they are wrapped with electrical tape because this was a trial run. We later used some heat shrink on them.
Tuck the headphone cord into the existing slot in the back of the tape player as shown.
Take the other end and run it through the slot where the tape player sits, down behind the dash, and out the bottom of the dash. This was the cleanest way we could find without drilling/cutting.
Put everything back the way it came out, and wa-la.
I'll get some final product pictures up here tomorrow probably. I got a little over excited and forgot to get a few. Since this is not an Ipod specific cord, it can be used with anything that works with headphones. Another nice touch is that when the headphone cord is plugged into a cell phone, you can use it sort of like a redneck bluetooth and hear your phone via the truck's speakers.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
