I just got finished installing a new set of leather heated and cooled seats in my 2009 Silverado. I had the powered heated seats but no cooling. I had a Cadillac with the heated/cooled seats in it and loved them. I don't see why GM does not put these in a Silverado. You can get them in Suburbans,Denali's, and most GM SUV's, etc. but not the Silverado.
I saw a post several months ago by "rich22" on this forum about installing these in his truck. I sent him a PM and he sent me instructions and diagrams on how to install and ordered me a set of the new seats in my color from the manufacturer to match my interior exactly.The only thing that is different on the outside of the seats is that the center sections of the seat leather is perforated-not solid like the orginals. I really like it better because it has a softer feel, not near as stiff as the solid leather on these trucks. rich22 (Richard) was very helpful and answered all my questions. The install wasn't too hard. The cooled seats are exactly like the orginal seats, they bolt in exactly the same. They even use the same electrical connector. The hardest part was the additional wiring between the seats and one power wire to the fuse block. But even that wasn't too bad. After getting them installed I had to take to the dealer to have the door and seat modules programmed with the Tech2. I am very happy with them-They are great.
The install looks 100% factory.
:D
How much denaro did they set you back?
With everything- both brand new front seats with all modules, driver's and passenger door seat control switches, wiring, programming, shipping etc- all about $2500
Sounds like a nice mod, a bit pricey for me but I wouldn't think twice if I lived in a hot humid climate 365 days a year!
Just curious how the actual cooling part works on these seats, how are they cooled?
They are cooled by a system called climate controlled seats CCS which
uses thermoelectric/peltier cooling/heating modules-a small heat pump/air
conditioner
Quote from website:
About CCS:
"In the CCS system, which is built around Amerigon's
highly-efficient, solid-state thermoelectric device, air is forced through the
heat pump and thermally conditioned in response to electronic switch input from
the seat occupant. The conditioned air circulates by a specially designed fan
through ducts in the seat cushion and seat back, so that the surface can be
heated or cooled. Each seat has individual electronic controls to adjust the
level of heating or cooling. CCS substantially improves comfort compared with
conventional air conditioners by focusing the cooling directly on the passenger
through the seat, rather than waiting until ambient air cools the seat surface
behind the passenger."
The cooling is accomplished by 2 in-seat peltier-style thermoelectric air conditioning units. Basically, electric current is passed through in one direction, making one side hot and the other side cold, and a blower motor pushes air across the cold side up through the perforations in the seats. For heating the seats, the system simply reverses the current across the peltier and blows air across the warm side into the seat. One unit is the seat bottom and one is in the seat back.
  • 8 months later...
Louie
Where did you order from. Could you send me the instructions. I have been asking my dealer about putting a ventilated seat in from a suburban/tahoe and they look at me like I got two heads. Glad to see that someone did this already
Thanks
Louie
Thanks
I got all the information and parts from rich22 on this forum. I don't have it now but if you can't contact him thru the forum send me a PM and I will sent you get his email address for you. He sold me all the parts I needed for the conversion including brand new seats and door switches and all installation instructions. By the way the seats still work great and it is really getting hot and humid here. The A/C in my truck works great but there is nothing like a cool seat when you have black leather and the truck sets all day in the sun.
Louie
I have a heated leather seat stock, is there a way to cool it without a complete replacement?
  • 3 years later...
I just installed LTZ heated/cooled seats in my 2009 Denali HD, along with the factory door panel switches. I just need to know what other connections need to be made for the cooling to work, thanks!
...just down the road from ya! Where did you get the seats?
Wouldn't this need to be coded in the bcm for the switches to work? Interested to see how this goes...would really like some cooled seats!
Another member said you had instructions to add heated/cooled seats. I just installed LTZ heated/cooled seats from a theft recovery truck in my Denali HD, along with the door panel switches. I just need to know what other connections/programming need to be made to get the cooling to work. Thanks in advance! Brian Coleman
[email protected]
Edited by kbclas2012
  • 1 year later...
I just got seats from a 2011 escalade with option code KB6 (heat/cool/memory) and installed them in my 2011 slt 2500 with option code AN3. I have the heat and cooling switch installed just need to know what to do next. truck already has a fuse for cooled seats but it looks as if the truck seat harness is missing wires from pin #'s B9-15 and I see that they are utilized on the NEW seat side harness. with further investigation I found B 9-15 is for KB6 code option. so in thinking that my lt3 (loaded) SLT sierra was pre-wired for KB6 option, I was wrong and now I feel like im up shits creek with a set of useless expensive seats.. can someone please pm me and lead me in the right direction? Thanks
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
