Heater Problem
gcally
I need some help! I have a 2006 GMC Sierra 1500 crew cab and the heat only blows hot when I am driving down the road.
For example if I start my truck in the morning and let it warm up to operating temperature the heat will only blow cold air. As soon as I start to drive down the road the heat will blow hot air after driving 10 seconds.
I already replaced all 4 blend door actuators (what a pain in the ***) and heater controls. Everything works fine once I start driving down the road. All 4 blend doors are working fine. I cannot think of what else I should check.
check your coolant level....this happened to me a couple weeks ago. the only time the heat would blow (even with the engine at full operating temp) is when I was accelerating down the road. if i coasted or idled it went back to blowing cool air. turned out I was a half gallon low in the resevoir tank :cheers: embaressing. first and easiest thing to check.
It is a little bit low I will try it and let you know.
What kind of rad fluid should I use? I think the truck still hase the stock stuff in it (red in color). Can I mix different kinds of rad fluid.
Thanks Greg
Use dexcool only. dont mix with regular antifreeze. the doesnt matter, orange, green, red, there all the same.
So you are saying that I can use any dexcool wether it is orange, green, or red and mix it with my stock rad fluid.
Every dexcool I've seen is orange in color....it's a trademark I do believe.
    DNL going
    DNL going
  • Who's Online   4 Members, 0 Anonymous, 520 Guests (See full list)
